Just did a "bulk" owncloud upgrade and ended with calendar not showing.
Datepic…ker is working fine for example in contacts.
Nothing in the webserver logs
No access to the database logged by postgres
Nothing in the JS console to help either
Trying to create a calendar also fails.
However sync seems fine with Android CallDav Sync, so looks like a JS problem...
### Steps to reproduce
1. Upgrade 8.2.7 -> 9.0.0 -> 9.0.4 -> 9.1.2  sorry :/
### Expected behaviour
Calendar to show :)
### Actual behaviour
### Server configuration
**Operating system**: 10.3-STABLE FreeBSD
**Web server:** Apache/2.4.23
**Database:** PostgreSQL 9.6.1
**PHP version:** 5.6.27
**Server version:** 9.1.2
**Calendar version:** 1.4.0.0
**Updated from an older installed version or fresh install:**
**Signing status (ownCloud/Nextcloud 9.0 and above):**
**List of activated apps:**
Enabled:
  - activity: 2.3.2
  - calendar: true
  - comments: 0.3.0
  - contacts: true
  - dav: 0.2.7
  - federatedfilesharing: 0.3.0
  - federation: 0.1.0
  - files: 1.5.1
  - files_pdfviewer: 0.8.1
  - files_sharing: 0.10.0
  - files_texteditor: 2.1
  - files_trashbin: 0.9.0
  - files_versions: 1.3.0
  - files_videoplayer: 0.9.8
  - firstrunwizard: 1.1
  - gallery: 15.0.0
  - notifications: 0.3.0
  - systemtags: 0.3.0
  - templateeditor: 0.1
  - updatenotification: 0.2.1
Disabled:
  - encryption
  - external
  - files_antivirus
  - files_external
  - provisioning_api
  - user_external
  - user_ldap
    "system": {
        "instanceid": "ocj19u7ggz5o",
        "trusted_domains": [
            "oc.gudul.net"
        "datadirectory": "\/usr\/local\/www\/owncloud\/data",
        "overwrite.cli.url": "https:\/\/oc.gudul.net",
        "dbtype": "pgsql",
        "version": "9.1.2.5",
        "dbname": "owncloud",
        "dbhost": "localhost",
        "dbtableprefix": "oc_",
        "installed": true,
        "forcessl": true,
        "forceSSLforSubdomains": true,
        "mail_smtpmode": "sendmail",
        "loglevel": 0,
        "mail_smtpsecure": "tls",
        "mail_from_address": "jeff",
        "mail_domain": "gudul.net",
        "mail_smtpauthtype": "LOGIN",
        "mail_smtpauth": 1,
        "mail_smtphost": "mail.gudul.net",
        "mail_smtpport": "25",
        "maintenance": false,
       "theme": "",
        "appstore.experimental.enabled": false,
        "trashbin_retention_obligation": "auto",
        "updater.secret": "***REMOVED SENSITIVE VALUE***",
        "htaccess.RewriteBase": "\/"
    "apps": {
        "activity": {
            "types": "filesystem",
            "enabled": "yes",
            "installed_version": "2.3.2"
        "backgroundjob": {
            "lastjob": "21"
        "calendar": {
            "types": "",
            "ocsid": "168707",
            "signed": "true",
            "installed_version": "0",
            "enabled": "yes"
        "comments": {
            "types": "logging",
            "enabled": "yes",
            "installed_version": "0.3.0"
        "contacts": {
            "types": "",
            "ocsid": "168708",
            "enabled": "yes",
        "core": {
            "installedat": "1432715178.386",
            "public_files": "files_sharing\/public.php",
            "public_gallery": "gallery\/public.php",
            "public_calendar": "calendar\/share.php",
            "public_caldav": "calendar\/share.php",
            "public_documents": "documents\/public.php",
            "repairlegacystoragesdone": "yes",
            "global_cache_gc_lastrun": "1447784100",
            "shareapi_default_expire_date": "yes",
            "backgroundjobs_mode": "cron",
            "shareapi_allow_public_upload": "no",
            "shareapi_enabled": "no",
            "lastupdateResult": "[]",
            "lastcron": "1480201200",
            "remote_files": "dav\/appinfo\/v1\/webdav.php",
            "remote_webdav": "dav\/appinfo\/v1\/webdav.php",
            "remote_dav": "dav\/appinfo\/v2\/remote.php",
            "remote_contacts": "dav\/appinfo\/v1\/carddav.php",
            "remote_carddav": "dav\/appinfo\/v1\/carddav.php",
            "remote_calendar": "dav\/appinfo\/v1\/caldav.php",
            "remote_caldav": "dav\/appinfo\/v1\/caldav.php",
            "public_webdav": "dav\/appinfo\/v1\/publicwebdav.php",
            "oc.integritycheck.checker": "[]",
            "updater.secret.created": "1480172206",
            "lastupdatedat": "1480200508"
        "dav": {
            "installed_version": "0.2.7",
            "enabled": "yes"
        "documents": {
            "installed_version": "0.9.0",
            "types": "",
            "ocsid": "168711",
            "enabled": "no"
        "federatedfilesharing": {
            "installed_version": "0.3.0",
            "types": "",
            "enabled": "yes"
        "federation": {
            "types": "authentication",
            "enabled": "yes",
            "installed_version": "0.1.0",
            "autoAddServers": "0"
        "files": {
            "enabled": "yes",
            "cronjob_scan_files": "500",
            "installed_version": "1.5.1"
        "files_locking": {
            "installed_version": "",
            "enabled": "no"
        "files_pdfviewer": {
            "ocsid": "166049",
            "types": "",
            "enabled": "yes",
            "installed_version": "0.8.1"
        "files_sharing": {
            "enabled": "yes",
            "outgoing_server2server_share_enabled": "no",
            "incoming_server2server_share_enabled": "no",
            "installed_version": "0.10.0"
        "files_texteditor": {
            "ocsid": "166051",
            "types": "",
            "enabled": "yes",
            "installed_version": "2.1"
        "files_trashbin": {
            "enabled": "yes",
        "files_versions": {
            "enabled": "yes",
            "installed_version": "1.3.0"
        "files_videoplayer": {
            "installed_version": "0.9.8",
            "types": "",
            "enabled": "yes"
        "files_videoviewer": {
            "installed_version": "0.1.3",
            "ocsid": "166054",
            "types": "",
            "enabled": "no"
        "firstrunwizard": {
            "installed_version": "1.1",
            "ocsid": "166055",
            "types": "",
            "enabled": "yes"
        "gallery": {
            "types": "",
            "enabled": "yes",
            "installed_version": "15.0.0"
        "mail": {
            "installed_version": "0.2.1",
            "types": "",
            "ocsid": "169914",
            "enabled": "no"
        "notifications": {
            "types": "logging",
            "enabled": "yes",
        "provisioning_api": {
            "installed_version": "0.2",
            "enabled": "no"
        "systemtags": {
            "types": "logging",
            "enabled": "yes",
        "templateeditor": {
            "installed_version": "0.1",
            "types": "",
            "enabled": "yes"
        "updatenotification": {
            "types": "",
            "enabled": "yes"
        "updater": {
            "types": "",
            "installed_version": "0.6",
            "enabled": "no"
**Are you using external storage, if yes which one:**
No
**Are you using encryption:**
No
**Are you using an external user-backend, if yes which one:**
No
### Client configuration
**Browser:** firefox 50.0 / Chrome 54.0.2840.99 m
**Operating system:** windows
**CalDAV-clients:** Android CalDav Sync Adapter
### Logs
#### Web server error log
None
#### Log file (data/owncloud.log)
None
#### Browser log
None
