1.fresh install of LAMP
2.installed latest 10.0.10 OC
3.try to open OC in firefox with just domain name
Install page should show
Php source code of index.php was shown instead.
After tried everything, I typed in https://domain.com/index.php and install wizard showed up.
After it finished, I can access the site with https://domain.com/index.php/index.php/app/…
So basically, the site doesn’t work if I don’t specify a particular php file.
ubuntu 16.04
apache2.4.18
mysqlnd 5.0.12
10.0.10.4
fresh
downloaded from owncloud
"system": {
"instanceid": "ocd6bhruscpk",
"trusted_domains": [
"domain.com"
"datadirectory": "\/var\/www\/html\/owncloud\/data",
"overwrite.cli.url": "https:\/\/domain.com",
"dbtype": "mysql",
"version": "10.0.10.4",
"dbname": "owncloud",
"dbhost": "localhost",
"dbtableprefix": "oc_",
"mysql.utf8mb4": true,
"logtimezone": "UTC",
"installed": true
