Hi there,
does anyone know about implementation of 2 factor authentifcation with FortiAuthenticator of Fortinet?
norman
Hi there,
norman
The product sounds like an IdP.
If it is and it supports OIDC or SAML2 then you can setup SSO with ownCloud (SAML2 is Enterprise Edition only). Once implemented you can enable 2FA for the users in there.
If not, then it is probably not possible, but I don’t know anything about this product, so…
