Hi guys,
we have the following issue, where I can not sync ownCloud from Thunderbird. The error is:
The calendar is momentarily not available.
It is really weird because at the same time I can sync the ownCloud calendar with iCalender on Mac OS and it works fine. I have installed
Lightning with both SOGo Add-ons. The SPDY is not enabled, so this could not be the problem in our case, I think. I have tried different scenarios, but without success.
Expected behaviour:
Calender in Thunderbird is synced with the calendar in ownCloud
Actual behaviour:
Error which says that the calendar is not available.
Versions:
OwnCloud 9.1.1
Mac OS X Sierra 10.12.01
Thunderbird 45.7.0
Lightning 4.7.4
SOGoConnector 31.0.3
SOGo Integrator 31.0.3
Server: nginx/1.10.0 (Ubuntu)
upstream php-handler {
server XXX.X.X.X:XXXX;
Server unix:/var/run/php5-fpm.sock;
server {
listen 80;
server_name _;
#server_name cloud.example.com;
# enforce https
#listen 443 ssl; #server_name cloud.example.com;
#ssl_certificate /etc/ssl/nginx/cloud.example.com.crt; #ssl_certificate_key /etc/ssl/nginx/cloud.example.com.key;
# Add headers to serve security related headers # Before enabling Strict-Transport-Security headers please read into this topic first. #add_header Strict-Transport-Security "max-age=15552000; includeSubDomains"; add_header X-Content-Type-Options nosniff; add_header X-Frame-Options "SAMEORIGIN"; add_header X-XSS-Protection "1; mode=block"; add_header X-Robots-Tag none; add_header X-Download-Options noopen; add_header X-Permitted-Cross-Domain-Policies none;
#rewrite ^/.well-known/carddav /remote.php/carddav$1 permanent;
#rewrite ^/caldav(.)$ /remote.php/caldav$1 redirect;
#rewrite ^/carddav(.)$ /remote.php/carddav$1 permanent;
#rewrite ^/webdav(.*)$ /remote.php/webdav$1 redirect;# Path to the root of your installation root /XXXX/XXXX/XXX/XXX;
location = /robots.txt { allow all; log_not_found off; access_log off; }
#location ~ ^/(?:.htaccess|data|config|db_structure.xml|README){
#deny all;
# The following 2 rules are only needed for the user_webfinger app.
# Uncomment it if you’re planning to use this app.
# rewrite ^/.well-known/host-meta /public.php?service=host-meta last;
# rewrite ^/.well-known/host-meta.json /public.php?service=host-meta-json last;location = /.well-known/carddav { return 301 $scheme://$host/remote.php/dav; } location = /.well-known/caldav { return 301 $scheme://$host/remote.php/dav; } location /.well-known/acme-challenge { } #experimenting 20170124 henning shterion #add_header Allow "GET, POST, HEAD PROPFIND" always; # set max upload size client_max_body_size 512M; fastcgi_buffers 64 4K; # Disable gzip to avoid the removal of the ETag header gzip off; # Uncomment if your server is build with the ngx_pagespeed module # This module is currently not supported. #pagespeed off; error_page 403 /core/templates/403.php; error_page 404 /core/templates/404.php; location / { rewrite ^ /index.php$uri; } location ~ ^/(?:build|tests|config|lib|3rdparty|templates|data)/ { return 404; } location ~ ^/(?:\.|autotest|occ|issue|indie|db_|console) { return 404; } location ~ ^/(?:index|remote|public|cron|core/ajax/update|status|ocs/v[12]|updater/.+|ocs-provider/.+|core/templates/40[34])\.php(?:$|/) { fastcgi_split_path_info ^(.+\.php)(/.*)$; include fastcgi_params; fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name; fastcgi_param PATH_INFO $fastcgi_path_info; #fastcgi_param HTTPS on;fastcgi_param modHeadersAvailable true; #Avoid sending the security >headers twice
fastcgi_param front_controller_active true;
fastcgi_pass php-handler;
fastcgi_intercept_errors on;
fastcgi_request_buffering off; #Available since nginx 1.7.11
location ~ ^/(?:updater|ocs-provider)(?:$|/) { try_files $uri $uri/ =404; index index.php; }
# Adding the cache control header for js and css files # Make sure it is BELOW the PHP block location ~* \.(?:css|js)$ { try_files $uri /index.php$uri$is_args$args; #add_header Cache-Control "public, max-age=7200"; # Add headers to serve security related headers (It is intended to have those duplicated to the ones above) # Before enabling Strict-Transport-Security headers please read into this topic first. #add_header Strict-Transport-Security "max-age=15552000; includeSubDomains"; #add_header X-Content-Type-Options nosniff; #add_header X-Frame-Options "SAMEORIGIN"; #add_header X-XSS-Protection "1; mode=block"; #add_header X-Robots-Tag none; #add_header X-Download-Options noopen; #add_header X-Permitted-Cross-Domain-Policies none; # Optional: Don't log access to assets # access_log off; }
location ~* \.(?:svg|gif|png|html|ttf|woff|ico|jpg|jpeg)$ { try_files $uri /index.php$uri$is_args$args; # Optional: Don't log access to other assets #access_log off; }}
