Cannot change upload_max_filesize on a owncloud docker container v10.15.0
  1. Install an owncloud container v10.15.0 with docker.
  2. Trying to modify upload_max_filesize value to 1GB.
    2.1 Via global environment OWNCLOUD_MAX_UPLOAD=1G in docker-compose.yaml file.
    2.2 Modifyng the value in owncloud root folder .htaccess and .users.ini
    2.3 Modifying the value in the file /etc/php/7.4/cli/php.ini and /etc/php/7,4/apache2/php.ini
Uploads must be limited to 1GB.
I can upload files without limits.
Ubuntu 20.04
172.18.0.4:8080 Not securized yet.
Create with docker-compose in another container
10.15.0
Fresh install.
On my local machine.
OK
  Integrity checker has been disabled. Integrity cannot be verified.
“system”: {
“apps_paths”: [
“path”: “/var/www/owncloud/apps”,
“url”: “/apps”,
“writable”: false
“path”: “/var/www/owncloud/custom”,
“url”: “/custom”,
“writable”: true
“trusted_domains”: [
“localhost:8087”,
“172.18.0.100:8080”,
“192.168.18.251:8087”
“datadirectory”: “/mnt/data/files”,
“dbtype”: “mysql”,
“dbhost”: “mariadb”,
“dbname”: “owncloud”,
“dbtableprefix”: “oc_”,
“log_type”: “owncloud”,
“supportedDatabases”: [
“sqlite”,
“mysql”,
“pgsql”
“upgrade.disable-web”: true,
“default_language”: “es”,
“overwrite.cli.url”: “http://172.18.0.100:8080/”,
“htaccess.RewriteBase”: “/”,
“logfile”: “/mnt/data/files/owncloud.log”,
“memcache.local”: “\OC\Memcache\APCu”,
“mysql.utf8mb4”: true,
“filelocking.enabled”: true,
“memcache.distributed”: “\OC\Memcache\Redis”,
“memcache.locking”: “\OC\Memcache\Redis”,
“redis”: {
“host”: “redis”,
“port”: “6379”
“version”: “10.15.0.2”,
“dbconnectionstring”: “”,
“allow_user_to_change_mail_address”: “”,
“logtimezone”: “UTC”,
“installed”: true,
“instanceid”: “ociwg729mtt8”
root@9e69025c5e8a:/var/www/owncloud# cat /etc/os-release
NAME=“Ubuntu”
VERSION=“20.04.6 LTS (Focal Fossa)”
ID=ubuntu
ID_LIKE=debian
PRETTY_NAME=“Ubuntu 20.04.6 LTS”
VERSION_ID=“20.04”
HOME_URL=“”
SUPPORT_URL=“”
BUG_REPORT_URL=“”
PRIVACY_POLICY_URL=“”
VERSION_CODENAME=focal
UBUNTU_CODENAME=focal
root@9e69025c5e8a:/var/www/owncloud# cd config
root@9e69025c5e8a:/var/www/owncloud/config# nano config.php
root@9e69025c5e8a:/var/www/owncloud/config# cd …
root@9e69025c5e8a:/var/www/owncloud# sudo -u www-data php occ config:list system
“system”: {
“apps_paths”: [
“url”: “/apps”,
“writable”: false
“url”: “/custom”,
“writable”: true
“localhost:8087”,
“dbtype”: “mysql”,
“sqlite”,
“mysql”,
“pgsql”
“redis”: {
“host”: “redis”,
“port”: “6379”
“installed”: true,
“instanceid”: “ociwg729mtt8”,
“integrity.check.disabled”: true
**List of activated apps:**
  - activity:
    - Version: 2.7.2
  - comments:
    - Version: 0.3.0
  - configreport:
    - Version: 0.3.0
  - dav:
    - Version: 0.7.0
  - diagnostics:
    - Version: 0.2.1
    - Path: /var/www/owncloud/apps/diagnostics
  - federatedfilesharing:
    - Version: 0.5.0
  - federation:
    - Version: 0.1.0
  - files:
    - Version: 1.6.0
  - files_external:
    - Version: 0.9.0
  - files_mediaviewer:
    - Version: 1.0.5
  - files_pdfviewer:
    - Version: 1.0.2
  - files_sharing:
    - Version: 0.14.0
  - files_texteditor:
    - Version: 2.6.1
    - Path: /var/www/owncloud/apps/files_texteditor
  - files_trashbin:
    - Version: 0.9.1
  - files_versions:
    - Version: 1.3.0
  - firstrunwizard:
    - Version: 1.3.0
  - market:
    - Version: 0.9.0
  - notifications:
    - Version: 0.6.0
  - provisioning_api:
    - Version: 0.5.0
  - systemtags:
    - Version: 0.3.0
  - updatenotification:
    - Version: 0.2.1
Disabled:
  - admin_audit:
    - Path: /var/www/owncloud/apps/admin_audit
  - announcementcenter:
    - Path: /var/www/owncloud/apps/announcementcenter
  - customgroups:
    - Path: /var/www/owncloud/apps/customgroups
  - drawio:
    - Path: /var/www/owncloud/apps/drawio
  - encryption:
  - enterprise_key:
    - Path: /var/www/owncloud/apps/enterprise_key
  - external:
  - files_antivirus:
    - Path: /var/www/owncloud/apps/files_antivirus
  - files_classifier:
    - Path: /var/www/owncloud/apps/files_classifier
  - files_external_dropbox:
    - Path: /var/www/owncloud/apps/files_external_dropbox
  - files_external_ftp:
    - Path: /var/www/owncloud/apps/files_external_ftp
  - files_ldap_home:
    - Path: /var/www/owncloud/apps/files_ldap_home
  - files_lifecycle:
    - Path: /var/www/owncloud/apps/files_lifecycle
  - files_primary_s3:
    - Path: /var/www/owncloud/apps/files_primary_s3
  - firewall:
    - Path: /var/www/owncloud/apps/firewall
  - graphapi:
    - Path: /var/www/owncloud/apps/graphapi
  - guests:
    - Path: /var/www/owncloud/apps/guests
  - impersonate:
    - Path: /var/www/owncloud/apps/impersonate
  - kerberos:
    - Path: /var/www/owncloud/apps/kerberos
  - metrics:
    - Path: /var/www/owncloud/apps/metrics
  - oauth2:
    - Path: /var/www/owncloud/apps/oauth2
  - onlyoffice:
    - Path: /var/www/owncloud/apps/onlyoffice
  - openidconnect:
    - Path: /var/www/owncloud/apps/openidconnect
  - password_policy:
    - Path: /var/www/owncloud/apps/password_policy
  - ransomware_protection:
    - Path: /var/www/owncloud/apps/ransomware_protection
  - sharepoint:
    - Path: /var/www/owncloud/apps/sharepoint
  - systemtags_management:
    - Path: /var/www/owncloud/apps/systemtags_management
  - templateeditor:
    - Path: /var/www/owncloud/apps/templateeditor
  - theme-enterprise:
    - Path: /var/www/owncloud/apps/theme-enterprise
  - user_external:
  - user_ldap:
    - Path: /var/www/owncloud/apps/user_ldap
  - user_shibboleth:
    - Path: /var/www/owncloud/apps/user_shibboleth
  - web:
    - Path: /var/www/owncloud/apps/web
  - windows_network_drive:
    - Path: /var/www/owncloud/apps/windows_network_drive
  - wopi:
    - Path: /var/www/owncloud/apps/wopi
  - workflow:
    - Path: /var/www/owncloud/apps/workflow
No
No
No
### Client configuration
**Browser:**
Google Chrome.
**Operating system:**
Ubuntu 20.04
### Logs
#### Web server error log
is empty
from what i know / have read in the past ownCloud is uploading files in smaller “chunks” of around 15 MB so i don’t think that this setting can be used to limit the maximal allowed file size because i think a 1 GB large file will be still uploaded in such smaller chunks.
Hi! To fix upload_max_filesize in your ownCloud Docker container:
  1. Update php.ini: Ensure changes are in both CLI and Apache php.ini files.
  2. Verify .htaccess and .user.ini: Check if settings are applied correctly.
  3. Restart Container: Restart Docker after changes.
  4. Check Docker Env Variables: Confirm OWNCLOUD_MAX_UPLOAD is set correctly.
If the problem persists, check Docker logs for errors. Hope this helps!
Thank you very much for your response, this would explain a lot of things.
Thanks for the response. Those are the steps that I am following precisely when establishing that parameter. Even so, it still allows any upload limit
