Cannot Log in to web interface after fresh install
1.Visted Website
2.Attempt to log in
3.
Owncloud webpanel
Cannot even click login. Desktop app can connect and syns default account. Issue seems to be web interface only. Seems to happen with all versions of owncloud even though i was previously running owncloud 7 without issue. However i set that up quite some time ago, so i cant rule out user error/
Operating system: CentOS 6.8
Web server:Kloxo
Database: 5.5.52
PHP version: 5.4.25
ownCloud version (see ownCloud admin page):
attempted with:
6
7
8
9
All variations
I attempted both an upgrade and fresh install.
None
{"reqId":"dnrbN5zKTcRigSzhGgzv","remoteAddr":"162.158.34.57","app":"mysql.setup","message":"Specific user creation failed: An exception occurred while executing 'SELECT user FROM mysql.user WHERE user=?' with params [\"oc_admin\"]:\n\nSQLSTATE[42000]: Syntax error or access violation: 1142 SELECT command denied to user 'thebox'@'localhost' for table 'user'","level":3,"time":"2016-12-22T01:41:38+00:00","method":"POST","url":"\/index.php","user":"--"}
{"reqId":"dnrbN5zKTcRigSzhGgzv","remoteAddr":"162.158.34.57","app":"mysql.setup","message":"Database creation failed: An exception occurred while executing 'GRANT ALL PRIVILEGES ON `thebox` . * TO 'thebox'':\n\nSQLSTATE[42000]: Syntax error or access violation: 1044 Access denied for user 'thebox'@'localhost' to database 'thebox'","level":3,"time":"2016-12-22T01:41:38+00:00","method":"POST","url":"\/index.php","user":"--"}
{"reqId":"RnupQN+nvEEqKC7wUAlg","remoteAddr":"162.158.34.57","app":"PHP","message":"chmod(): Operation not permitted at \/home\/admin\/box.snipesearch.co.uk\/lib\/private\/legacy\/util.php#925","level":3,"time":"2016-12-22T01:41:51+00:00","method":"GET","url":"\/index.php\/apps\/files\/","user":"admin"}
{"reqId":"Ho+YDwN7cWgLWpLszWpp","remoteAddr":"162.158.34.57","app":"PHP","message":"chmod(): Operation not permitted at \/home\/admin\/box.snipesearch.co.uk\/lib\/private\/legacy\/util.php#925","level":3,"time":"2016-12-22T01:42:52+00:00","method":"GET","url":"\/index.php\/apps\/files\/","user":"admin"}
{"reqId":"KOOJujZZVK1+jXWLelsu","remoteAddr":"162.158.34.57","app":"PHP","message":"session_write_close(): open(\/var\/lib\/php\/session\/sess_603025a96490f98132757ff6285d8dca, O_RDWR) failed: Permission denied (13) at \/home\/admin\/box.snipesearch.co.uk\/lib\/private\/Session\/Internal.php#103","level":3,"time":"2016-12-22T12:13:07+00:00","method":"GET","url":"\/status.php","user":"--"}
{"reqId":"KOOJujZZVK1+jXWLelsu","remoteAddr":"162.158.34.57","app":"PHP","message":"session_write_close(): Failed to write session data (files). Please verify that the current setting of session.save_path is correct (\/var\/lib\/php\/session) at \/home\/admin\/box.snipesearch.co.uk\/lib\/private\/Session\/Internal.php#103","level":3,"time":"2016-12-22T12:13:07+00:00","method":"GET","url":"\/status.php","user":"--"}
{"reqId":"hS719CfLBr5GhV3XbHXT","remoteAddr":"162.158.34.57","app":"PHP","message":"session_write_close(): open(\/var\/lib\/php\/session\/sess_7f6905b49abfc0f84daadda614440676, O_RDWR) failed: Permission denied (13) at \/home\/admin\/box.snipesearch.co.uk\/lib\/private\/Session\/Internal.php#103","level":3,"time":"2016-12-22T12:13:11+00:00","method":"GET","url":"\/status.php","user":"--"}
{"reqId":"hS719CfLBr5GhV3XbHXT","remoteAddr":"162.158.34.57","app":"PHP","message":"session_write_close(): Failed to write session data (files). Please verify that the current setting of session.save_path is correct (\/var\/lib\/php\/session) at \/home\/admin\/box.snipesearch.co.uk\/lib\/private\/Session\/Internal.php#103","level":3,"time":"2016-12-22T12:13:11+00:00","method":"GET","url":"\/status.php","user":"--"}
{"reqId":"1ZEhLXamY3bqYxXnwlkI","remoteAddr":"162.158.34.57","app":"PHP","message":"session_write_close(): open(\/var\/lib\/php\/session\/sess_2224f8d29f8cf53c73c7aa9604591ce7, O_RDWR) failed: Permission denied (13) at \/home\/admin\/box.snipesearch.co.uk\/lib\/private\/Session\/Internal.php#103","level":3,"time":"2016-12-22T12:13:20+00:00","method":"GET","url":"\/status.php","user":"--"}
{"reqId":"1ZEhLXamY3bqYxXnwlkI","remoteAddr":"162.158.34.57","app":"PHP","message":"session_write_close(): Failed to write session data (files). Please verify that the current setting of session.save_path is correct (\/var\/lib\/php\/session) at \/home\/admin\/box.snipesearch.co.uk\/lib\/private\/Session\/Internal.php#103","level":3,"time":"2016-12-22T12:13:20+00:00","method":"GET","url":"\/status.php","user":"--"}
{"reqId":"Vux+3B3JkIc9olXNZDT4","remoteAddr":"162.158.34.57","app":"PHP","message":"session_write_close(): open(\/var\/lib\/php\/session\/sess_2c2fce332227878baf7d65915651eab0, O_RDWR) failed: Permission denied (13) at \/home\/admin\/box.snipesearch.co.uk\/lib\/private\/Session\/Internal.php#103","level":3,"time":"2016-12-22T12:13:26+00:00","method":"GET","url":"\/index.php\/login","user":"--"}
{"reqId":"Vux+3B3JkIc9olXNZDT4","remoteAddr":"162.158.34.57","app":"PHP","message":"session_write_close(): Failed to write session data (files). Please verify that the current setting of session.save_path is correct (\/var\/lib\/php\/session) at \/home\/admin\/box.snipesearch.co.uk\/lib\/private\/Session\/Internal.php#103","level":3,"time":"2016-12-22T12:13:26+00:00","method":"GET","url":"\/index.php\/login","user":"--"}
Integrity status for oC9+
Technical information
them.
Results
- core
	- INVALID_HASH
		- core/doc/admin/release/_sources/configuration_files/collaborative_documents_configuration.txt
		- core/doc/admin/release/_static/img/note_pencil.svg
		- core/doc/admin/release/_static/img/warning.svg
		- core/fonts/LICENSE.txt
		- core/vendor/jsTimezoneDetect/jstz.js
- files_texteditor
	- INVALID_HASH
		- js/vendor/ace/src-noconflict/mode-diff.js
- files_external
	- INVALID_HASH
		- 3rdparty/Dropbox/API.php
Raw output
Array
    [core] => Array
            [INVALID_HASH] => Array
                    [core/doc/admin/release/_sources/configuration_files/collaborative_documents_configuration.txt] => Array
                            [expected] => 251befed4a319c8e4b390b363a9bc8079b54991891204a4ff1cb551797931ba9f276903e1e5e8bde932afcb5e67d23f7939cea22e68c6bd7695e2b8ce654c5b3
                            [current] => 637ac6c02e3ef06cc19a9b465c5c0e6ae6777f9e5d5d52cae28482f350e3b348a5c3ba67ae693e95971373c326af98c27c7f04492aa836b6ab1348f7341ccb29
                    [core/doc/admin/release/_static/img/note_pencil.svg] => Array
                            [expected] => 78b9df57afe9468145e6e375cd1f61274b269b9c3019726a99e043ae952367acf53cf471cbc5b3dcca2e68367c2c4422d4a9f9a9fdbb11f9b962845ac77857de
                            [current] => 97117ce2827cc1b742678b52fc100de1e7d3fdb1adeea04a301c012e7f95b66e10a369c6a83ba89a707c4232b5e31fba3d5e58b0e0d970f22031d0704eebb5a9
                    [core/doc/admin/release/_static/img/warning.svg] => Array
                            [expected] => e8647b47ef1531b8c2fcdd51f76996fe85476467fc694540f3dcf8ce7e7da489e99edae5a158742da71c07dc09ccfaf721f01c1c4bda3f5bae9b711981b71a1b
                            [current] => 85687f19cf204716e9b1c608682aa22c045b6f8284a3496db07f13200952491bfea54deee7ef11115c0dedfd87443c7022ef05792892a8a984866752c8ec5726
                    [core/fonts/LICENSE.txt] => Array
                            [expected] => 4cc5a12bfe984c0a50bf7943e2d70a948d520ef423677c77629707aace3a95aa378d205de929105d644680679e70ef2449479b360ad44896b75bafed66613272
                            [current] => 98f6b79b778f7b0a15415bd750c3a8a097d650511cb4ec8115188e115c47053fe700f578895c097051c9bc3dfb6197c2b13a15de203273e1a3218884f86e90e8
                    [core/vendor/jsTimezoneDetect/jstz.js] => Array
                            [expected] => ece74dd6f5fc9587cf167dd17df51b66f70bd711f445da8d1d21bb1b0570f3c97b25d3ece110b08e2f2b294369d9b775cc169b666840a5b769ba338aa6d73d48
                            [current] => beae737d18aae6e8c5fdfb0bf3389b687ec746e6b334185710cc5b8f45b73b3c57442db541807ab440b55517ef2d138f4c40148abafcb6462481016b617e1f53
    [files_texteditor] => Array
                    [js/vendor/ace/src-noconflict/mode-diff.js] => Array
                            [expected] => 4a59b6376376b81e4e12ccc345065db62029a61035a88e19b1be3d7ec4cd9f86444121cca6d46c44a5f86e4f5b44d5109cbc77e80c07ff8dbce61f758b88e765
                            [current] => 298cba4d3b472b418aca47db6522c752a4b5530de3f6f2d83eb42eb5fe4231356bfd860a7e2f735b3e5ced759dbc6ca26fc6a18c49bd7ffa07d5a6faa78ae51d
    [files_external] => Array
                    [3rdparty/Dropbox/API.php] => Array
                            [expected] => a6866ef3ceeb26d9d4b2ccc343aeaf626c82f03e279962bc7d761a68e87e5a7916ff0bcf7a350e20889557336ed9c5dd1651cfe513fa04bb8a03cd6d8f9cc484
                            [current] => 917eed2c4f6359a4d0b8658a36404c83344b0bf72ccda614dd59f97d099b3d9ef4e86691401c64d3754c3f7e0fa163eab946a25dbc7bc65e1694ffd47a054317
You have a broken permission setup for this folder on operating system level. Please contact a support community of your used distro to get help with that.
Thats a gread start, thank you. Any idea why its started doing it now? can i redifine the session path in owncloud.
A session path needs to be configured globally in your PHP configuration or the permissions to the session path needs to be fixed so your webservers user can write into it.
I Have 10 sites on the server, all of them are writing to the sessions path as the Apache user, its only own cloud failing to do so. I checked the owner it is the web server. Clip bucket successfully utilising folder as well as other scripts.
Which is no prove at all. They might implement a session handling on their own or doing other magic non-conform stuff. The message is clearly showing that PHP native methods are utilized and that those are failing.
I appreciate that, but i am able to write a short script that is able to write its own session using standard methods. It succeeds, i have also Checked ownership and the directory is owned by Apache. Where does it write the session data (as in what file controls it). Although since the directory does have Own cloud files in it, this seems to be a red herring, but i would at the very least like to investigate it further.
{"reqId":"otmGY53BY3rMqZ0I0LVx","remoteAddr":"162.158.34.57","app":"webdav","message":"Exception: {\"Message\":\"HTTP\\\/1.1 400 expected filesize 10000000 got 4439805\",\"Exception\":\"Sabre\\\\DAV\\\\Exception\\\\BadRequest\",\"Code\":0,\"Trace\":\"#0 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/File.php(103): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\File->createFileChunked(Resource id #384)\\n#1 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/Directory.php(136): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\File->put(Resource id #384)\\n#2 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(1036): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\Directory->createFile('20150201113626....', Resource id #384)\\n#3 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/CorePlugin.php(523): Sabre\\\\DAV\\\\Server->createFile('Dropbox\\\/Camera ...', Resource id #384, NULL)\\n#4 [internal function]: Sabre\\\\DAV\\\\CorePlugin->httpPut(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#5 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/3rdparty\\\/sabre\\\/event\\\/lib\\\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\\n#6 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(459): Sabre\\\\Event\\\\EventEmitter->emit('method:PUT', Array)\\n#7 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(248): Sabre\\\\DAV\\\\Server->invokeMethod(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#8 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/apps\\\/dav\\\/appinfo\\\/v1\\\/webdav.php(56): Sabre\\\\DAV\\\\Server->exec()\\n#9 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/remote.php(164): require_once('\\\/home\\\/admin\\\/box...')\\n#10 {main}\",\"File\":\"\\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/File.php\",\"Line\":404,\"User\":\"admin\"}","level":4,"time":"2016-12-22T17:40:34+00:00","method":"PUT","url":"\/remote.php\/webdav\/Dropbox\/Camera%20Uploads\/01-02-2015(2)\/20150201113626.m2ts-chunking-3562439726-645-449","user":"admin"}
{"reqId":"E041Etp7AxPNUYvpbHHh","remoteAddr":"162.158.34.57","app":"webdav","message":"Exception: {\"Message\":\"HTTP\\\/1.1 400 expected filesize 8970379 got 4439875\",\"Exception\":\"Sabre\\\\DAV\\\\Exception\\\\BadRequest\",\"Code\":0,\"Trace\":\"#0 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/Directory.php(136): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\File->put(Resource id #384)\\n#1 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(1036): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\Directory->createFile('snipesearch_9.s...', Resource id #384)\\n#2 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/CorePlugin.php(523): Sabre\\\\DAV\\\\Server->createFile('Dropbox\\\/Databas...', Resource id #384, NULL)\\n#3 [internal function]: Sabre\\\\DAV\\\\CorePlugin->httpPut(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#4 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/3rdparty\\\/sabre\\\/event\\\/lib\\\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\\n#5 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(459): Sabre\\\\Event\\\\EventEmitter->emit('method:PUT', Array)\\n#6 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(248): Sabre\\\\DAV\\\\Server->invokeMethod(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#7 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/apps\\\/dav\\\/appinfo\\\/v1\\\/webdav.php(56): Sabre\\\\DAV\\\\Server->exec()\\n#8 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/remote.php(164): require_once('\\\/home\\\/admin\\\/box...')\\n#9 {main}\",\"File\":\"\\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/File.php\",\"Line\":149,\"User\":\"admin\"}","level":4,"time":"2016-12-22T17:41:33+00:00","method":"PUT","url":"\/remote.php\/webdav\/Dropbox\/Databases\/snipesearch_9.sql","user":"admin"}
{"reqId":"Sf8TiiM39Vu2sqhW1fjl","remoteAddr":"162.158.34.57","app":"webdav","message":"Exception: {\"Message\":\"HTTP\\\/1.1 400 expected filesize 10000000 got 4439761\",\"Exception\":\"Sabre\\\\DAV\\\\Exception\\\\BadRequest\",\"Code\":0,\"Trace\":\"#0 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/File.php(103): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\File->createFileChunked(Resource id #384)\\n#1 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/Directory.php(136): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\File->put(Resource id #384)\\n#2 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(1036): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\Directory->createFile('00002.MTS-chunk...', Resource id #384)\\n#3 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/CorePlugin.php(523): Sabre\\\\DAV\\\\Server->createFile('CAMERA FOOTAGE ...', Resource id #384, NULL)\\n#4 [internal function]: Sabre\\\\DAV\\\\CorePlugin->httpPut(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#5 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/3rdparty\\\/sabre\\\/event\\\/lib\\\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\\n#6 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(459): Sabre\\\\Event\\\\EventEmitter->emit('method:PUT', Array)\\n#7 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(248): Sabre\\\\DAV\\\\Server->invokeMethod(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#8 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/apps\\\/dav\\\/appinfo\\\/v1\\\/webdav.php(56): Sabre\\\\DAV\\\\Server->exec()\\n#9 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/remote.php(164): require_once('\\\/home\\\/admin\\\/box...')\\n#10 {main}\",\"File\":\"\\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/File.php\",\"Line\":404,\"User\":\"admin\"}","level":4,"time":"2016-12-22T17:41:43+00:00","method":"PUT","url":"\/remote.php\/webdav\/CAMERA%20FOOTAGE%20-%20KELLY%20AND%20LAURA%20-%20DESELECT%20THIS%20FOLDER\/Christening%202015\/00002.MTS-chunking-1414967631-213-3","user":"admin"}
{"reqId":"CLdENN5aoe9X3S+dms9O","remoteAddr":"162.158.34.57","app":"webdav","message":"Exception: {\"Message\":\"HTTP\\\/1.1 400 expected filesize 10000000 got 4437008\",\"Exception\":\"Sabre\\\\DAV\\\\Exception\\\\BadRequest\",\"Code\":0,\"Trace\":\"#0 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/File.php(103): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\File->createFileChunked(Resource id #384)\\n#1 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/Directory.php(136): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\File->put(Resource id #384)\\n#2 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(1036): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\Directory->createFile('snipesearch_4.s...', Resource id #384)\\n#3 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/CorePlugin.php(523): Sabre\\\\DAV\\\\Server->createFile('Dropbox\\\/Databas...', Resource id #384, NULL)\\n#4 [internal function]: Sabre\\\\DAV\\\\CorePlugin->httpPut(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#5 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/3rdparty\\\/sabre\\\/event\\\/lib\\\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\\n#6 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(459): Sabre\\\\Event\\\\EventEmitter->emit('method:PUT', Array)\\n#7 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(248): Sabre\\\\DAV\\\\Server->invokeMethod(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#8 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/apps\\\/dav\\\/appinfo\\\/v1\\\/webdav.php(56): Sabre\\\\DAV\\\\Server->exec()\\n#9 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/remote.php(164): require_once('\\\/home\\\/admin\\\/box...')\\n#10 {main}\",\"File\":\"\\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/File.php\",\"Line\":404,\"User\":\"admin\"}","level":4,"time":"2016-12-22T17:41:53+00:00","method":"PUT","url":"\/remote.php\/webdav\/Dropbox\/Databases\/snipesearch_4.sql-chunking-3677003968-24-1","user":"admin"}
{"reqId":"BH+\/2PoTBAnyQ0TLZE2M","remoteAddr":"162.158.34.57","app":"webdav","message":"Exception: {\"Message\":\"HTTP\\\/1.1 400 expected filesize 10000000 got 4439826\",\"Exception\":\"Sabre\\\\DAV\\\\Exception\\\\BadRequest\",\"Code\":0,\"Trace\":\"#0 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/File.php(103): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\File->createFileChunked(Resource id #384)\\n#1 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/Directory.php(136): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\File->put(Resource id #384)\\n#2 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(1036): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\Directory->createFile('snipesearch_4 (...', Resource id #384)\\n#3 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/CorePlugin.php(523): Sabre\\\\DAV\\\\Server->createFile('Dropbox\\\/Databas...', Resource id #384, NULL)\\n#4 [internal function]: Sabre\\\\DAV\\\\CorePlugin->httpPut(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#5 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/3rdparty\\\/sabre\\\/event\\\/lib\\\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\\n#6 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(459): Sabre\\\\Event\\\\EventEmitter->emit('method:PUT', Array)\\n#7 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(248): Sabre\\\\DAV\\\\Server->invokeMethod(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#8 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/apps\\\/dav\\\/appinfo\\\/v1\\\/webdav.php(56): Sabre\\\\DAV\\\\Server->exec()\\n#9 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/remote.php(164): require_once('\\\/home\\\/admin\\\/box...')\\n#10 {main}\",\"File\":\"\\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/File.php\",\"Line\":404,\"User\":\"admin\"}","level":4,"time":"2016-12-22T17:42:02+00:00","method":"PUT","url":"\/remote.php\/webdav\/Dropbox\/Databases\/snipesearch_4%20(2).sql-chunking-3681791395-71-8","user":"admin"}
{"reqId":"X3UwejkHNDWTTLUpwA9y","remoteAddr":"162.158.34.57","app":"webdav","message":"Exception: {\"Message\":\"HTTP\\\/1.1 400 expected filesize 10000000 got 4434186\",\"Exception\":\"Sabre\\\\DAV\\\\Exception\\\\BadRequest\",\"Code\":0,\"Trace\":\"#0 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/File.php(103): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\File->createFileChunked(Resource id #384)\\n#1 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/Directory.php(136): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\File->put(Resource id #384)\\n#2 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(1036): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\Directory->createFile('snipesearchuk.s...', Resource id #384)\\n#3 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/CorePlugin.php(523): Sabre\\\\DAV\\\\Server->createFile('Dropbox\\\/Databas...', Resource id #384, NULL)\\n#4 [internal function]: Sabre\\\\DAV\\\\CorePlugin->httpPut(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#5 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/3rdparty\\\/sabre\\\/event\\\/lib\\\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\\n#6 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(459): Sabre\\\\Event\\\\EventEmitter->emit('method:PUT', Array)\\n#7 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(248): Sabre\\\\DAV\\\\Server->invokeMethod(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#8 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/apps\\\/dav\\\/appinfo\\\/v1\\\/webdav.php(56): Sabre\\\\DAV\\\\Server->exec()\\n#9 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/remote.php(164): require_once('\\\/home\\\/admin\\\/box...')\\n#10 {main}\",\"File\":\"\\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/File.php\",\"Line\":404,\"User\":\"admin\"}","level":4,"time":"2016-12-22T17:42:14+00:00","method":"PUT","url":"\/remote.php\/webdav\/Dropbox\/Databases\/snipesearchuk.sql-chunking-1805831305-3-0","user":"admin"}
{"reqId":"G33QXhnpfSUxR2xJIm1P","remoteAddr":"162.158.34.57","app":"webdav","message":"Exception: {\"Message\":\"HTTP\\\/1.1 400 expected filesize 10000000 got 4439830\",\"Exception\":\"Sabre\\\\DAV\\\\Exception\\\\BadRequest\",\"Code\":0,\"Trace\":\"#0 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/File.php(103): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\File->createFileChunked(Resource id #384)\\n#1 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/Directory.php(136): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\File->put(Resource id #384)\\n#2 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(1036): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\Directory->createFile('snipesearchuk_3...', Resource id #384)\\n#3 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/CorePlugin.php(523): Sabre\\\\DAV\\\\Server->createFile('Dropbox\\\/Databas...', Resource id #384, NULL)\\n#4 [internal function]: Sabre\\\\DAV\\\\CorePlugin->httpPut(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#5 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/3rdparty\\\/sabre\\\/event\\\/lib\\\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\\n#6 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(459): Sabre\\\\Event\\\\EventEmitter->emit('method:PUT', Array)\\n#7 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(248): Sabre\\\\DAV\\\\Server->invokeMethod(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#8 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/apps\\\/dav\\\/appinfo\\\/v1\\\/webdav.php(56): Sabre\\\\DAV\\\\Server->exec()\\n#9 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/remote.php(164): require_once('\\\/home\\\/admin\\\/box...')\\n#10 {main}\",\"File\":\"\\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/File.php\",\"Line\":404,\"User\":\"admin\"}","level":4,"time":"2016-12-22T17:42:45+00:00","method":"PUT","url":"\/remote.php\/webdav\/Dropbox\/Databases\/snipesearchuk_3.sql-chunking-1949012259-14-0","user":"admin"}
{"reqId":"iyMibF9ZXn+SDPtB\/gLY","remoteAddr":"162.158.34.57","app":"webdav","message":"Exception: {\"Message\":\"HTTP\\\/1.1 400 expected filesize 10000000 got 4439780\",\"Exception\":\"Sabre\\\\DAV\\\\Exception\\\\BadRequest\",\"Code\":0,\"Trace\":\"#0 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/File.php(103): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\File->createFileChunked(Resource id #384)\\n#1 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/Directory.php(136): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\File->put(Resource id #384)\\n#2 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(1036): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\Directory->createFile('2016-10-11_03-2...', Resource id #384)\\n#3 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/CorePlugin.php(523): Sabre\\\\DAV\\\\Server->createFile('Dropbox\\\/Natalis...', Resource id #384, NULL)\\n#4 [internal function]: Sabre\\\\DAV\\\\CorePlugin->httpPut(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#5 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/3rdparty\\\/sabre\\\/event\\\/lib\\\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\\n#6 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(459): Sabre\\\\Event\\\\EventEmitter->emit('method:PUT', Array)\\n#7 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(248): Sabre\\\\DAV\\\\Server->invokeMethod(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#8 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/apps\\\/dav\\\/appinfo\\\/v1\\\/webdav.php(56): Sabre\\\\DAV\\\\Server->exec()\\n#9 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/remote.php(164): require_once('\\\/home\\\/admin\\\/box...')\\n#10 {main}\",\"File\":\"\\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/File.php\",\"Line\":404,\"User\":\"admin\"}","level":4,"time":"2016-12-23T02:42:34+00:00","method":"PUT","url":"\/remote.php\/webdav\/Dropbox\/Natalis%20XXX%20Videos%20Complete\/CHATURBATE%20SHOWS\/2016-10-11_03-27-07.mp4-chunking-4266694525-434-13","user":"admin"}
{"reqId":"97dKRVDUH63PJBTXFYIb","remoteAddr":"162.158.34.57","app":"webdav","message":"Exception: {\"Message\":\"HTTP\\\/1.1 400 expected filesize 10000000 got 4439753\",\"Exception\":\"Sabre\\\\DAV\\\\Exception\\\\BadRequest\",\"Code\":0,\"Trace\":\"#0 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/File.php(103): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\File->createFileChunked(Resource id #384)\\n#1 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/Directory.php(136): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\File->put(Resource id #384)\\n#2 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(1036): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\Directory->createFile('00004.MTS-chunk...', Resource id #384)\\n#3 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/CorePlugin.php(523): Sabre\\\\DAV\\\\Server->createFile('CAMERA FOOTAGE ...', Resource id #384, NULL)\\n#4 [internal function]: Sabre\\\\DAV\\\\CorePlugin->httpPut(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#5 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/3rdparty\\\/sabre\\\/event\\\/lib\\\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\\n#6 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(459): Sabre\\\\Event\\\\EventEmitter->emit('method:PUT', Array)\\n#7 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/3rdparty\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(248): Sabre\\\\DAV\\\\Server->invokeMethod(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#8 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/apps\\\/dav\\\/appinfo\\\/v1\\\/webdav.php(56): Sabre\\\\DAV\\\\Server->exec()\\n#9 \\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/remote.php(164): require_once('\\\/home\\\/admin\\\/box...')\\n#10 {main}\",\"File\":\"\\\/home\\\/admin\\\/box.snipesearch.co.uk\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/File.php\",\"Line\":404,\"User\":\"admin\"}","level":4,"time":"2016-12-23T10:47:44+00:00","method":"PUT","url":"\/remote.php\/webdav\/CAMERA%20FOOTAGE%20-%20KELLY%20AND%20LAURA%20-%20DESELECT%20THIS%20FOLDER\/Kelly%20show%2007-002-2015\/00004.MTS-chunking-1414404824-213-1","user":"admin"}
