I am not able to login in owncloud using the Administrator user, I tried to reset the password using the below command but it doesnt work.
root@72e26072fbc2: / # sudo -u www-data /var/www/owncloud/occ user:resetpassword Administrator
Enter a new password:
Confirm the new password:
Error while resetting password!
Can you check with the occ user:list command that the user Administrator exists? Usually it is called admin.
Otherwise you can figure out with the command occ group:list-members admin which user ids have admin rights inside your ownCloud.
Finally when creating a Server topic, there is an issue template that needs to be filled out so that users of this forum are able to help.
Hi Thanks for the response yes it exists as Administrator, if i try the occ command with an unknown user it says the user is not found.
root@72e26072fbc2: /var/www/owncloud # occ user:list
Perhaps you can rerun the occ change password command with a -vvv flag so it outputs errors (not sure it supports this flag though)?
Or have a look in the ownCloud log whether there is an error message?
Didn’t help, the last option is to uninstall owncloud from univention and install it again.
These are the only log files i found which doesnt show any errors
/var/lib/univention-appcenter/apps/owncloud/data/files/owncloud-appcenter.log
/var/lib/univention-appcenter/apps/owncloud/data/files/owncloud.log
That’s why you need to fill out the template.
Univention Appliance uses LDAP, the user is not in ownCloud but in Univention -> change password in Univention.
