Hello everyone,
recently i has been success installed owncloud 10.2 and working properly until login, but after that i can’t upload files and create folder [interface upload not showing]
like this :
https://i.imgur.com/BhyPVkt.png
anyone can solved this,
Regards,
ivink3aray
Are you sure you are using ownCloud 10.2? This looks like a lower version. (The logo is on the right, in newer versions of ownCloud it is centred.)
sorry this version is 10.0.2 (stable)
https://i.imgur.com/Ura6ZmV.png
This is a server issue (it was originally filed in development), and in order to help you effectively we need the template filled out.
I would recommend to make sure that your ownCloud version is up to date. (10.3.1) For everything else we need to know how your ownCloud is set up (OS/Docker?/PHP version/…), but that’s what the template is for.
i has been upgrade to owncloud version 10.3.1 but still error no display upload files
myserver using debian 9.0
nginx webserver
mariadb database
upgrade
https://i.ibb.co/M1LCC2c/upgrade.png
Please make sure that you use a proven nginx configuration, most docs about ownCloud will only show you how to set it up with Apache.
Make sure that single-user mode is not enabled (occ maintenance:singleuser --off) and have a look in the owncloud.log file in your data directory.
cscherm
December 10, 2019, 11:59am
7
Do you use some blocking tools in your browser or in the system preferences of your OS?
Please also take a look at the Network tab in your browser inspect console (F12). Please verify that every status reports 200.
it seems there is a FAQ category available here: FAQ - ownCloud Central
I quickly browsed through this category and found the following topic which seems to be about this issue:
Problem
There is no “Add (+)” button on the “Files” page of ownCloud as shown on the following screenshot:
[image]
Description
Since ownCloud 9.1 the “files” app providing this button is also using the WebDAV interface of ownCloud. If this WebDAV interface is broken (you might also get an “Your web server is not yet properly setup to allow files synchronization because the WebDAV interface seems to be broken.” in your admin backend) the button won’t show up.
Solutions
Please follow the lin…
