docker server
version is 10.14.0
The vertical photos cannot be loaded on the web side, while the horizontal photos are fine.
These vertical photos are taken partly with a camera and partly with a cell phone.
docker server
version is 10.14.0
could this be related to this?
Thank u, that is the problem.
i insert 'preview_max_dimensions' => '6016x6016' to config.php and the picture can be shown.
The preview_max_dimensions setting was not properly reflected in the docs.
Iâve taken this portrait/landscape example to expand the docs.
Maybe someone wants to produce a PR to update the default so that both landscape and portrait are first class citizens?
fixed in server version 10.15.0
Hello Cherrs,
I am very happy finding your solution here because I have the same problem.
I am stuck with the auto upgrade from 10.14.0.3 to version 10.15.0 so I would like to to insert âpreview_max_dimensionsâ => â6016x6016â in the config.php
I tried to insert it at the end of the config.php but without success!
Could you help me please?
Manx thanks, JClaude
i think it could be maybe makes sense what the âbut without successâ means. And i think it could be also possible that it could make sense to create a new topic for support on how to edit a file correctly.
Are u asking u donât know how to edit config.php, or u have edited it already but the configuration hasnât take effect
Thank you for your reply Cherrs!
I donât know where in the php file to put your line, thatâs my problem.
I put it at the beginning, no effect.
I put it at the end, Owncloud didnât started anymore.
Could you put your php file here to show where you put the âpreview_max_dimensionsâ => â6016x6016â
The other solution would be to make the update to 10.15.0 but I canât, see the error message in another post.
What do you think?
Thank you very much Cherrs, this time it works.
I think it was the position in the lines and also the comma at the end of the line.
I still have to do the same on a second Owncloud in a few days.
I saw that you remained in version 10.14.0.3 while on 10.15.0 this problem seems resolved.
Once again THANK YOU very much.
Jean-Claude
