Cant add events in calendar in fresh installation of OC 9
  1. fresh install of OC 9.1.1
    2.Fresh install of calendar
  2. add event to calendar
Event should appear on screen after pressing update
nothing appears on that date
Operating system:linux
Web server: 2.6.32-604.30.3.lve1.3.63.el6.x86_64 - webhost
Database: mysql
PHP version: 7
ownCloud version (see ownCloud admin page): 9.1.1
Updated from an older ownCloud or fresh install:fresh
Integrity status for oC9+
paste the results here.
no errors have been found
three pointers:
  • Check various browsers (Internet Explorer and Edge for example are not supported in the Calendar app)
  • Check the WebDAV interface of your browser with the litmus test explained here: How to compile and run litmus (on debian) for WebDAV tests
    – > Shared hosters / webhosters are known that they have quite often broken setups for such WebDAV connections which is causing such issues
  • Check the error console of your browser for possible errors when creating this event
