Can't Configure Admin Login: Raspbian, RaspBerry Pi2 and Owncloud
Create Admin Login
Webpage where I create the Admin Login times out.
Operating system: Raspbian Jessie (4/16/18)
Web server: Raspberry Pi2
Database: SQL Lite
ownCloud version: (see ownCloud admin page) 10.0.6
Updated from an older ownCloud or fresh install: No
**Where did you install ownCloud from:**sudo wget https://download.owncloud.org/community/owncloud-10.0.6.tar.bz2
Are you using external storage, if yes which one: local usb drive
Are you using encryption: no
**Are you using an external user-backend, if yes which one:**No
Hey, if this is a fresh install you probably should choose version 10.0.8 together with a MySQL database.
Thank you, tom42 - That did the trick. I am able to login using the newly created Password and User credentials.
In my case, I’m going to rebuild because the Raspberry Pi 2 just doesn’t seem to have enough firepower… or at least what I expected. On to the Pi 3b. :slight_smile:
Thanks for your help.
