- Download the latest owncloud version via apt-get in command line.
- Upgrade through the web interface of the owncloud server.
Showing the login page after upgrade
Instead I got the following message:
Exception occurred while logging exception: Failed to connect to the database: An exception occured in driver: SQLSTATE[HY000] [2002] No such file or directory #0 /var/www/owncloud/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(429): OC\DB\Connection->connect() #1 /var/www/owncloud/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(389): Doctrine\DBAL\Connection->getDatabasePlatformVersion() #2 /var/www/owncloud/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(328): Doctrine\DBAL\Connection->detectDatabasePlatform() #3 /var/www/owncloud/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/Connection.php(623): Doctrine\DBAL\Connection->getDatabasePlatform() #4 /var/www/owncloud/lib/private/DB/Connection.php(144): Doctrine\DBAL\Connection->setTransactionIsolation(2) #5 /var/www/owncloud/lib/composer/doctrine/dbal/lib/Doctrine/DBAL/DriverManager.php(172): OC\DB\Connection->__construct(Array, Object(Doctrine\DBAL\Driver\PDOMySql\Driver), Object(Doctrine\DBAL\Configuration), Object(Doctrine\Common\EventManager)) #6 /var/www/owncloud/lib/private/DB/ConnectionFactory.php(145): Doctrine\DBAL\DriverManager::getConnection(Array, Object(Doctrine\DBAL\Configuration), Object(Doctrine\Common\EventManager)) #7 /var/www/owncloud/lib/private/Server.php(532): OC\DB\ConnectionFactory->getConnection('mysql', Array) #8 /var/www/owncloud/lib/composer/pimple/pimple/src/Pimple/Container.php(118): OC\Server->OC\{closure}(Object(OC\Server)) #9 /var/www/owncloud/lib/private/AppFramework/Utility/SimpleContainer.php(108): Pimple\Container->offsetGet('DatabaseConnect...') #10 /var/www/owncloud/lib/private/ServerContainer.php(86): OC\AppFramework\Utility\SimpleContainer->query('DatabaseConnect...') #11 /var/www/owncloud/lib/private/Server.php(1220): OC\ServerContainer->query('DatabaseConnect...') #12 /var/www/owncloud/lib/private/Server.php(250): OC\Server->getDatabaseConnection() #13 /var/www/owncloud/lib/composer/pimple/pimple/src/Pimple/Container.php(118): OC\Server->OC\{closure}(Object(OC\Server)) #14 /var/www/owncloud/lib/private/AppFramework/Utility/SimpleContainer.php(108): Pimple\Container->offsetGet('AccountMapper') #15 /var/www/owncloud/lib/private/ServerContainer.php(86): OC\AppFramework\Utility\SimpleContainer->query('AccountMapper') #16 /var/www/owncloud/lib/private/Server.php(1066): OC\ServerContainer->query('AccountMapper') #17 /var/www/owncloud/lib/private/Server.php(256): OC\Server->getAccountMapper() #18 /var/www/owncloud/lib/composer/pimple/pimple/src/Pimple/Container.php(118): OC\Server->OC\{closure}(Object(OC\Server)) #19 /var/www/owncloud/lib/private/AppFramework/Utility/SimpleContainer.php(108): Pimple\Container->offsetGet('UserManager') #20 /var/www/owncloud/lib/private/ServerContainer.php(86): OC\AppFramework\Utility\SimpleContainer->query('UserManager') #21 /var/www/owncloud/lib/private/Server.php(1059): OC\ServerContainer->query('UserManager') #22 /var/www/owncloud/lib/private/Server.php(316): OC\Server->getUserManager() #23 /var/www/owncloud/lib/composer/pimple/pimple/src/Pimple/Container.php(118): OC\Server->OC\{closure}(Object(OC\Server)) #24 /var/www/owncloud/lib/private/AppFramework/Utility/SimpleContainer.php(108): Pimple\Container->offsetGet('UserSession') #25 /var/www/owncloud/lib/private/ServerContainer.php(86): OC\AppFramework\Utility\SimpleContainer->query('UserSession') #26 /var/www/owncloud/lib/private/Server.php(1083): OC\ServerContainer->query('UserSession') #27 /var/www/owncloud/lib/private/Log.php(436): OC\Server->getUserSession() #28 /var/www/owncloud/lib/public/Util.php(169): OC\Log->logException(Array, Array) #29 /var/www/owncloud/lib/base.php(435): OCP\Util::logException('base', Object(Doctrine\DBAL\DBALException)) #30 /var/www/owncloud/lib/base.php(587): OC::initSession() #31 /var/www/owncloud/lib/base.php(1005): OC::init() #32 /var/www/owncloud/index.php(53): require_once('/var/www/ownclo...') #33 {main}
Operating system: Raspbian/Debian 9.11 Stretch
Web server: Apache/2.4.25 (Raspbian)
Database: mysql Ver 15.1 Distrib 10.1.38-MariaDB, for debian-linux-gnueabihf (armv7l) using readline 5.2
PHP version: PHP 7.0.33-0+deb9u6 (cli) (built: Oct 24 2019 18:50:20) ( NTS )
ownCloud version: ownCloud Core [10.3.2] (2019-12-04)
Updated from an older ownCloud or fresh install: updated from earlier version
It looks to me like a permissions issue…!?
When I try to restart mysql with sudo service mysql restart, I get:
Job for mariadb.service failed because a fatal signal was delivered to the control process.
See “systemctl status mariadb.service” and “journalctl -xe” for details.
journalctl -xe brings me:
– Unit mariadb.service has begun starting up.
Dec 18 07:36:37 raspcloud mysqld[25529]: 2019-12-18 7:36:37 1996169008 [Note] /usr/sbin/mysqld (mysqld 10.1.38-MariaDB-0+deb9u1) starting as
Dec 18 07:36:38 raspcloud systemd[1]: mariadb.service: Main process exited, code=killed, status=6/ABRT
Dec 18 07:36:38 raspcloud systemd[1]: Failed to start MariaDB 10.1.38 database server.
– Subject: Unit mariadb.service has failed
– Defined-By: systemd
– Support: […]
– Unit mariadb.service has failed.
– The result is failed.
Dec 18 07:36:38 raspcloud systemd[1]: mariadb.service: Unit entered failed state.
Dec 18 07:36:38 raspcloud systemd[1]: mariadb.service: Failed with result ‘signal’.
Dec 18 07:36:43 raspcloud systemd[1]: mariadb.service: Service hold-off time over, scheduling restart.
Dec 18 07:36:43 raspcloud systemd[1]: Stopped MariaDB 10.1.38 database server.
– Subject: Unit mariadb.service has finished shutting down
– Support: […]
– Unit mariadb.service has finished shutting down.
Any ideas how to fix this?
Thank you very much!
Lenny
you can get it back up and running
