I’ve set up a test deployment with bare OCIS and I’m super impressed. Thus I’ve tried setting it up with Collabora - and failed. I can’t use config script provided with OCIS full as I need to get it working with reverse proxy I have in my lab (Nginx PM with Let’sEncrypt certs).
I’ve came up with following compose.yaml file :
services:
ocis:
container_name: ocis
hostname: ocis
image: owncloud/ocis:latest
restart: unless-stopped
entrypoint:
- /bin/sh
command: ["-c", "ocis init || true; ocis server"]
expose:
- 9200
volumes:
- $PWD/config:/etc/ocis
- $PWD/data:/var/lib/ocis
ports:
- "9200:9200"
- "9233:9233"
environment:
DEMO_USERS: false
PROXY_TLS: false
PROXY_ENABLE_BASIC_AUTH: "false"
OCIS_INSECURE: false
OCIS_URL: https://testocis.mydomain.app
PROXY_HTTP_ADDR: 0.0.0.0:9200
OCIS_LOG_LEVEL: info
OCIS_LOG_COLOR: true
OCIS_LOG_PRETTY: true
COLLABORA_DOMAIN: testdocserv.mydomain.app
FRONTEND_APP_HANDLER_SECURE_VIEW_APP_ADDR: com.owncloud.api.collaboration.CollaboraOnline
GATEWAY_GRPC_ADDR: 0.0.0.0:9142
MICRO_REGISTRY_ADDRESS: 127.0.0.1:9233
NATS_NATS_HOST: 0.0.0.0
NATS_NATS_PORT: "9233"
collabora:
container_name: collabora
cap_add:
- MKNOD
command:
- bash
- -c
- coolconfig generate-proof-key ; /start-collabora-online.sh
environment:
DONT_GEN_SSL_CERT: "YES"
aliasgroup1: https://testwopi.mydomain.app:443
extra_params: |
--o:ssl.enable=false \
--o:ssl.ssl_verification=false \
--o:ssl.termination=true \
--o:welcome.enable=false \
--o:net.frame_ancestors=testocis.mydomain.app
password: admin
username: admin
healthcheck:
test:
- CMD
- curl
- -f
- http://localhost:9980/hosting/discovery
image: collabora/code:24.04.12.3.1
ports:
- 9980:9980
logging:
driver: local
restart: always
collaboration:
container_name: collaboration
cap_add:
- NET_ADMIN
command:
- -c
- ocis collaboration server
depends_on:
collabora:
condition: service_healthy
required: true
ocis:
condition: service_started
required: true
entrypoint:
- /bin/sh
ports:
- "9300:9300"
- "9301:9301"
environment:
COLLABORATION_APP_ADDR: https://testdocserv.mydomain.app
COLLABORATION_APP_ICON: https://testdocserv.mydomain.app/favicon.ico
COLLABORATION_APP_INSECURE: "true"
COLLABORATION_APP_NAME: CollaboraOnline
COLLABORATION_APP_PRODUCT: Collabora
COLLABORATION_CS3API_DATAGATEWAY_INSECURE: "true"
COLLABORATION_GRPC_ADDR: 0.0.0.0:9301
COLLABORATION_HTTP_ADDR: 0.0.0.0:9300
COLLABORATION_LOG_LEVEL: info
COLLABORATION_WOPI_SRC: https://testwopi.mydomain.app
MICRO_REGISTRY: nats-js-kv
MICRO_REGISTRY_ADDRESS: ocis:9233
image: owncloud/ocis-rolling:latest
logging:
driver: local
restart: always
volumes:
volumes:
ocis-config:
ocis-data:
And while the components start the connection is not working. The Collabora app is registered and I can click create new .odt (etc.) doc - but that just brings blank page.
Collabora shows OK when I try to visit tesdocserv.mydomain.app .
Any suggestions, including troubleshooting suggestions that may help in nailing the problem down? What am I missing?
BTW - when I’ve been looking at the file generated by default OCIS Full I’ve noticed COMPANION_DOMAIN env variable, but can’t find mention of it in the docs.
