- Attempt to add SMB based on correct values
- Check SMB sharing through windows to be sure it works, and it does
- Red Box on ownCloud
Should show I green box and connect I presume? Haven’t had it work yet
Red box and no errors
Operating system: Windows
Web server: ?
Database: MariaDB
PHP version: Doesn’t say
ownCloud version: (see ownCloud admin page) 10.15.0.2
Updated from an older ownCloud or fresh install: Fresh Install
Where did you install ownCloud from: Owncloud docker image
Signing status (ownCloud 9.0 and above): Where is this?
https://gist.github.com/Marshy-Madness/1c7e0d28e7fa3dee4ae6113ba5e796d6
https://gist.github.com/Marshy-Madness/7ee64d4fc90ce492d6295a92e96fc4e0
Are you using external storage, if yes which one: Trying to use SMB but not working
Are you using encryption: No
Browser: Edge, Firefox and Chrome
Operating system: WIndows and android
