- Install latest VirtualBox
- Import latest appliance Image
- start VM
I’d like to install.
After some loading i get the message “internal server error: could not connect to the module process”. I can click “ok” and nothing happens. I can reach the VM via a browser and get a login screen, but as far as i understand it, the password is set during installation, which does not start.
Operating system: Windows Server 2008 R2
ownCloud version: latest VirtualBox Appliance (DL 21.09.2018)
Updated from an older ownCloud or fresh install: fresh image
**Where did you install ownCloud from:**owncloud.org
--> i cant login, i can not start the installation
edit: some more information … i searched for this error and someone wrote that switching to SCSI storage mmight help. Did change that in virtualbox, didnt change behaviour. The VM gets an ip, i can reach it via a browser.
I just installed a fresh VirtualBox and the latest appliance, which should work out-of-the-box …
I’d prefer having an appliance install for hyper-v, but i understood that hyper-v isnt supported anymore.
Anything i can try?
