Can't install on fresh Raspbi OS
1.Create a new raspberry pi OS bit lite 64b with raspberry imager
2.follow the step of “How to install ownCloud Infinite Scale on a Raspberry Pi in 4 easy steps - ownCloud” tutorial on the offical owncloud site
after execution of the .sh the OCIS should be installed and accessible by the web browser.
Tell us what happens instead :
at the laster step, to execture the .sh script the result is this error :
The jwt_secret has not been set properly in your config for ocis. Make sure your /root/.ocis/config config contains the proper values (e.g. by running ocis init or setting it manually in the config/corresponding environment variable).
Raspberry pi os Version: 20230214
OCIS 3.0.0
Fresh Install
Owncloud tuto and source
Might be a little late, but did you run ocis init?
Also when posting here, remove anything from the template you did not actually use/need/modify, thx.
