I’m preparing to move my owncloud server to new hardware.
I’m using a test-server to test the migration, but I’m having problems.
My test-server runs ubuntu 20.04LTS, the database is MariaDB, php 7.4 (all stock ubuntu packages).
I installed OC 10.13.4.1, community version.
I created a backup of my production server’s database and restored it to the test-server.
I restored a backup of the data-files to a data-directory of the test-server.
I modified config.php of the production-server to the test-server to be usable for the test-server.
When I go to the web-page of the test-server, I can login, as root and as user. I think I’m seeing all files.
The problem is that I can’t read the files. When I try to open ownCloudUserManual.pdf, I get a message :
PDF.js v2.10.0 (build: c7a10e4)
Bericht: Missing PDF "http://cloud-test2/remote.php/webdav/ownCloudUserManual.pdf".
When I try to open/download example.odt I get a message :
## **Not Found**
## **Technische details**
* Extern adres: 192.168.xxx.30
* Aanvraag ID: XzgPWXqhofI52mRDE3IX
I found a post in this forum to test the data-directory like this :
sudo -u www-data touch /data/owncloud/user/documents/testfile
That works fine, also all directories leading up to that testfile are writable in the same way.
The pdf is where it should be, just like the odt-file (example files of owncloud).
I tried to look in the logging, but I can’ find anyhing usable.
Any ideas what is happening ? Or how to debug this ?
I didn’t try the client because I think the web-interface should work first.
Ubuntu 20.04.6 LTS
Apache version 2.4.41
MariaDB version 10.3.39
10.13.4.1
fresh install
owncloud-complete-20231213.tar.bz2
Is it OK to post that here ? The file has more than 7000 lines.
Enabled:
- activity:
- Version: 2.7.2
- calendar:
- Version: 2.0.0
- Path: /var/www/owncloud/apps/calendar
- comments:
- Version: 0.3.0
- configreport:
- Version: 0.2.2
- contacts:
- Version: 1.5.5
- Path: /var/www/owncloud/apps/contacts
- dav:
- Version: 0.7.0
- diagnostics:
- Version: 0.2.0
- Path: /var/www/owncloud/apps/diagnostics
- federatedfilesharing:
- Version: 0.5.0
- files:
- Version: 1.6.0
- files_external:
- Version: 0.9.0
- files_mediaviewer:
- Version: 1.0.5
- files_pdfviewer:
- Version: 1.0.2
- files_sharing:
- Version: 0.14.0
- files_texteditor:
- Version: 2.6.1
- Path: /var/www/owncloud/apps/files_texteditor
- files_trashbin:
- Version: 0.9.1
- files_versions:
- Version: 1.3.0
- firstrunwizard:
- Version: 1.3.0
- gallery:
- Version: 16.1.2
- Path: /var/www/owncloud/apps/gallery
- market:
- Version: 0.8.0
- notifications:
- Version: 0.6.0
- provisioning_api:
- Version: 0.5.0
- systemtags:
- Version: 0.3.0
- templateeditor:
- Version: 0.5.0
- Path: /var/www/owncloud/apps/templateeditor
- twofactor_totp:
- Version: 0.9.0
- Path: /var/www/owncloud/apps/twofactor_totp
- updatenotification:
- Version: 0.2.1
Disabled:
- encryption:
- external:
- federation:
- user_external:
no
no
Firefox 123
Chromium 122
Linux kubuntu 22.04 LTS
empty
more than 32MB, post here ?
15000 lines ?
