I use a desktop client on two computers (ubuntu & windows). FIles synchronise fine on both. However, I can’t see any file when I log in on the web interface. I’ve had this problem on previous versions without trying to solve it. It sometimes solved by updating.
The only files I can see are the one I’ve shared using a link when I was able to see them on previous versions clicking on “Shared by link”.
Operating system: *
**Web server: 10.2.1
**PHP version: 7.2.21
**ownCloud version: 10.2.1
**Updated from an older ownCloud or fresh install: updated
JQMIGRATE: Migrate is installed, version 1.4.0 jquery-migrate.min.js:2:552
window.controllers/Controllers est obsolète. Veuillez ne pas l’utiliser pour détecter l’agent utilisateur (UA). ace.js:1362
JQMIGRATE: jQuery.browser is deprecated jquery-migrate-1.0.0.js:29:12
Deprecation warning: tipsy is deprecated. Use tooltip instead. js.js:2311:10
autorefresh_option true
