- Attempt to upgrade 8.0.3 to the next version
- Follow all the instructions with my current version
- When time comes to press the Upgrade button, get an error: “Possible CSRF attack. Connection will be closed.”
- Go to owncloud directory and enter
sudo -u www-data php occ upgrade
The response is Exception: Updates between multiple major versions and downgrades are unsupported.
Well, I was hoping that as of step 3 above the upgrade would be completed with no errors.
The error listed above.
Operating system: Ubuntu 14.04 server
Web server: Apache 2.4.7
PHP version: 5.5.9
ownCloud version (see ownCloud admin page): 8.0.3
Updated from an older ownCloud or fresh install: This was a fresh install about a year ago
ownCloud log (data/owncloud.log, see How to find webserver or OC logfile / enable php logfile): It’s 2661 lines long…but tail owncloud.log is given below.
I’m a bit stumped… how do I upgrade?
{“reqId”:“5d803442bacb1e8033e038a1e372954a”,“remoteAddr”:“118.209.102.196”,“app”:“core”,“message”:“Invalid OCS content returned for app 166053”,“level”:4,“time”:“2016-07-31T11:10:40+00:00”}
{“reqId”:“5d803442bacb1e8033e038a1e372954a”,“remoteAddr”:“118.209.102.196”,“app”:“core”,“message”:“Invalid OCS content returned for app 166051”,“level”:4,“time”:“2016-07-31T11:10:40+00:00”}
{“reqId”:“5d803442bacb1e8033e038a1e372954a”,“remoteAddr”:“118.209.102.196”,“app”:“core”,“message”:“Invalid OCS content returned for app 166056”,“level”:4,“time”:“2016-07-31T11:10:41+00:00”}
{“reqId”:“5d803442bacb1e8033e038a1e372954a”,“remoteAddr”:“118.209.102.196”,“app”:“core”,“message”:“Invalid OCS content returned for app 166049”,“level”:4,“time”:“2016-07-31T11:10:42+00:00”}
{“reqId”:“5d803442bacb1e8033e038a1e372954a”,“remoteAddr”:“118.209.102.196”,“app”:“core”,“message”:“Invalid OCS content returned for app 166052”,“level”:4,“time”:“2016-07-31T11:10:43+00:00”}
{“reqId”:“Goli5vRelqF5PfBNvvY8”,“remoteAddr”:“118.209.102.196”,“app”:“index”,“message”:“Exception: {"Exception":"OC\\NeedsUpdateException","Message":"","Code":0,"Trace":"#0 \/var\/www\/owncloud\/lib\/private\/app.php(118): OC_App::loadApp(‘files’)\n#1 \/var\/www\/owncloud\/lib\/private\/util.php(130): OC_App::loadApps(Array)\n#2 \/var\/www\/owncloud\/lib\/base.php(850): OC_Util::setupFS()\n#3 \/var\/www\/owncloud\/index.php(39): OC::handleRequest()\n#4 {main}","File":"\/var\/www\/owncloud\/lib\/private\/app.php","Line":139}”,“level”:3,“time”:“2016-07-31T11:19:03+00:00”}
{“reqId”:“0He/TgF/7sd8Y9FPk7zc”,“remoteAddr”:“”,“app”:“core”,“message”:“starting upgrade from 8.0.3.4 to 8.2.1.4”,“level”:0,“time”:“2016-07-31T11:25:46+00:00”,“method”:“–”,“url”:“–”}
{“reqId”:“0He/TgF/7sd8Y9FPk7zc”,“remoteAddr”:“”,“app”:“core”,“message”:“Exception: {"Exception":"Exception","Message":"Updates between multiple major versions and downgrades are unsupported.","Code":0,"Trace":"#0 \/var\/www\/owncloud\/lib\/private\/updater.php(205): OC\\Updater->doUpgrade(‘8.2.1.4’, ‘8.0.3.4’)\n#1 \/var\/www\/owncloud\/core\/command\/upgrade.php(213): OC\\Updater->upgrade()\n#2 \/var\/www\/owncloud\/3rdparty\/symfony\/console\/Symfony\/Component\/Console\/Command\/Command.php(253): OC\\Core\\Command\\Upgrade->execute(Object(Symfony\\Component\\Console\\Input\\ArgvInput), Object(Symfony\\Component\\Console\\Output\\ConsoleOutput))\n#3 \/var\/www\/owncloud\/3rdparty\/symfony\/console\/Symfony\/Component\/Console\/Application.php(874): Symfony\\Component\\Console\\Command\\Command->run(Object(Symfony\\Component\\Console\\Input\\ArgvInput), Object(Symfony\\Component\\Console\\Output\\ConsoleOutput))\n#4 \/var\/www\/owncloud\/3rdparty\/symfony\/console\/Symfony\/Component\/Console\/Application.php(195): Symfony\\Component\\Console\\Application->doRunCommand(Object(OC\\Core\\Command\\Upgrade), Object(Symfony\\Component\\Console\\Input\\ArgvInput), Object(Symfony\\Component\\Console\\Output\\ConsoleOutput))\n#5 \/var\/www\/owncloud\/3rdparty\/symfony\/console\/Symfony\/Component\/Console\/Application.php(126): Symfony\\Component\\Console\\Application->doRun(Object(Symfony\\Component\\Console\\Input\\ArgvInput), Object(Symfony\\Component\\Console\\Output\\ConsoleOutput))\n#6 \/var\/www\/owncloud\/lib\/private\/console\/application.php(97): Symfony\\Component\\Console\\Application->run(NULL, NULL)\n#7 \/var\/www\/owncloud\/console.php(69): OC\\Console\\Application->run()\n#8 \/var\/www\/owncloud\/occ(11): require_once(‘\/var\/www\/ownclo…’)\n#9 {main}","File":"\/var\/www\/owncloud\/lib\/private\/updater.php","Line":285}”,“level”:3,“time”:“2016-07-31T11:25:46+00:00”,“method”:“–”,“url”:“–”}
{“reqId”:“LTV4r30iT5Gz1ySHF2uD”,“remoteAddr”:“”,“app”:“core”,“message”:“starting upgrade from 8.0.3.4 to 8.2.1.4”,“level”:0,“time”:“2016-07-31T11:28:06+00:00”,“method”:“–”,“url”:“–”}
{“reqId”:“LTV4r30iT5Gz1ySHF2uD”,“remoteAddr”:“”,“app”:“core”,“message”:“Exception: {"Exception":"Exception","Message":"Updates between multiple major versions and downgrades are unsupported.","Code":0,"Trace":"#0 \/var\/www\/owncloud\/lib\/private\/updater.php(205): OC\\Updater->doUpgrade(‘8.2.1.4’, ‘8.0.3.4’)\n#1 \/var\/www\/owncloud\/core\/command\/upgrade.php(213): OC\\Updater->upgrade()\n#2 \/var\/www\/owncloud\/3rdparty\/symfony\/console\/Symfony\/Component\/Console\/Command\/Command.php(253): OC\\Core\\Command\\Upgrade->execute(Object(Symfony\\Component\\Console\\Input\\ArgvInput), Object(Symfony\\Component\\Console\\Output\\ConsoleOutput))\n#3 \/var\/www\/owncloud\/3rdparty\/symfony\/console\/Symfony\/Component\/Console\/Application.php(874): Symfony\\Component\\Console\\Command\\Command->run(Object(Symfony\\Component\\Console\\Input\\ArgvInput), Object(Symfony\\Component\\Console\\Output\\ConsoleOutput))\n#4 \/var\/www\/owncloud\/3rdparty\/symfony\/console\/Symfony\/Component\/Console\/Application.php(195): Symfony\\Component\\Console\\Application->doRunCommand(Object(OC\\Core\\Command\\Upgrade), Object(Symfony\\Component\\Console\\Input\\ArgvInput), Object(Symfony\\Component\\Console\\Output\\ConsoleOutput))\n#5 \/var\/www\/owncloud\/3rdparty\/symfony\/console\/Symfony\/Component\/Console\/Application.php(126): Symfony\\Component\\Console\\Application->doRun(Object(Symfony\\Component\\Console\\Input\\ArgvInput), Object(Symfony\\Component\\Console\\Output\\ConsoleOutput))\n#6 \/var\/www\/owncloud\/lib\/private\/console\/application.php(97): Symfony\\Component\\Console\\Application->run(NULL, NULL)\n#7 \/var\/www\/owncloud\/console.php(69): OC\\Console\\Application->run()\n#8 \/var\/www\/owncloud\/occ(11): require_once(‘\/var\/www\/ownclo…’)\n#9 {main}","File":"\/var\/www\/owncloud\/lib\/private\/updater.php","Line":285}”,“level”:3,“time”:“2016-07-31T11:28:06+00:00”,“method”:“–”,“url”:“–”}
