Can't upgrade ownCloud using the web interface
I’ve been migrating my ownCloud instance to a new server, and I’ve been running to some issues. I posted about the first problem I had in this post. Now that I’ve migrated ownCloud to a new server, I want to upgrade it to the last version. I think I’m currently on 9.0.2, and the latest version is 9.0.4 (if it isn’t, please let me know!).
I’m trying to upgrade though the web interface, but I’m getting a white box and a 401 unauthorised error in the chrome dev console.
URL: https://owncloud.starbeamrainbowlabs.com/ocs/v2.php/apps/notifications/api/v1/notifications?format=json
Status code: 401
Response body:
{"ocs":{"meta":{"status":"failure","statuscode":997,"message":"Unauthorised"},"data":[]}}
I’m logged in as the administrator. Why would I not have permission to update my own server?
The webserver logfiles are perhaps a bit more helpful with this error. If you already experience code problems, I wouldn’t rely on the automatic updater app (which itself is not very reliable) and do a manual update.
  • Make Backup of all data and database
  • Remove all directories except of config/ and data/
  • Extract archive of new version (Changelog - ownCloud), set correct permissions (everything is at least readable by www-data, data/ and config/ must be writable)
  • Run update on terminal sudo -u www-data php occ upgrade
  • Via interface, you need to install your apps again (all data are in your database or data/-folder).
Thanks for your reply. Yeah, I was just wondering if there was an easy fix. I’ll add a manual update to my todo list.
(Apparently I have to wait 17 hours to post this)
I’ve just gotten around to doing that upgrade, and I’ve found that sudo -u www-data ./occ upgrade crashes!
Here’s the output:
The process control (PCNTL) extensions are required in case you want to interrupt long running commands - see http://php.net/manual/en/book.pcntl.php
Set log level to debug
Checking whether the database schema can be updated (this can take a long time depending on the database size)
 Done
 6/6 [============================] 100%
Checked database schema update
Checking updates of apps
Error: [] operator not supported for strings in /srv/owncloud/lib/private/App/InfoParser.php:186
Stack trace:
#0 /srv/owncloud/lib/private/App/InfoParser.php(188): OC\App\InfoParser->xmlToArray(Object(SimpleXMLElement))
#1 /srv/owncloud/lib/private/App/InfoParser.php(59): OC\App\InfoParser->xmlToArray(Object(SimpleXMLElement))
#2 /srv/owncloud/lib/private/legacy/app.php(662): OC\App\InfoParser->parse('/srv/owncloud/a...')
#3 /srv/owncloud/lib/private/Updater.php(310): OC_App::getAppInfo('files')
#4 /srv/owncloud/lib/private/Updater.php(235): OC\Updater->checkAppUpgrade('9.1.0.15')
#5 /srv/owncloud/lib/private/Updater.php(150): OC\Updater->doUpgrade('9.1.0.15', '9.0.2.2')
#6 /srv/owncloud/core/Command/Upgrade.php(290): OC\Updater->upgrade()
#7 /srv/owncloud/3rdparty/symfony/console/Command/Command.php(259): OC\Core\Command\Upgrade->execute(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#8 /srv/owncloud/3rdparty/symfony/console/Application.php(844): Symfony\Component\Console\Command\Command->run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#9 /srv/owncloud/3rdparty/symfony/console/Application.php(192): Symfony\Component\Console\Application->doRunCommand(Object(OC\Core\Command\Upgrade), Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#10 /srv/owncloud/3rdparty/symfony/console/Application.php(123): Symfony\Component\Console\Application->doRun(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#11 /srv/owncloud/lib/private/Console/Application.php(146): Symfony\Component\Console\Application->run(Object(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component\Console\Output\ConsoleOutput))
#12 /srv/owncloud/console.php(94): OC\Console\Application->run()
#13 /srv/owncloud/occ(11): require_once('/srv/owncloud/c...')
#14 {main}
please report this directly to: GitHub · Where software is built
Nothing what can be done here from user side so closing here to avoid that people are just reporting “me too”.
Thanks, here is the reference:
