Mount owncloud webdev volume to Windows or Mac OSx
Try to copy file from computer to Owncloud webdav volume > 200MB
Operating system : Fedora 29
Web server: Apache 2.4
PHP version: 7.2
ownCloud version: 10.0.10.4
I can not upload files greater than about 200mb with WebDAV. I mount the WebDAV volume on Windows and MacOS X and I’m getting the same problem.
I can upload the files just fine from the web interface.
This is the error in the owncloud.log file:
{“reqId”:“XK@NAZAvnr5LaoycCyBK8QAAAEM”,“level”:4,“time”:“2019-04-11T18:53:09+00:00”,“remoteAddr”:“172.16.2.88”,“user”:“Bob”,“app”:“webdav”,“method”:“PUT”,“url”:"/oc/remote.php/webdav/2014-02-02%2017.09.11.mp4",“message”:“Exception: HTTP/1.1 400 expected filesize 472688419 got 237666304: {“Exception”:“Sabre\\DAV\\Exception\\BadRequest”,“Message”:“expected filesize 472688419 got 237666304”,“Code”:0,“Trace”:”#0 \/var\/www\/html\/owncloud\/lib\/composer\/sabre\/dav\/lib\/DAV\/Server.php(1129): OCA\\DAV\\Connector\\Sabre\\File->put(Resource id #63 )\n#1 \/var\/www\/html\/owncloud\/lib\/composer\/sabre\/dav\/lib\/DAV\/CorePlugin.php(513): Sabre\\DAV\\Server->updateFile(‘2014-02-02 17.0…’, Resource id #63 , NULL)\n#2 [internal function]: Sabre\\DAV\\CorePlugin->httpPut(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#3 \/var\/www\/html\/owncloud\/lib\/composer\/sabre\/event\/lib\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\n#4 \/var\/www\/html\/owncloud\/lib\/composer\/sabre\/dav\/lib\/DAV\/Server.php(479): Sabre\\Event\\EventEmitter->emit(‘method:PUT’, Array)\n#5 \/var\/www\/html\/owncloud\/lib\/composer\/sabre\/dav\/lib\/DAV\/Server.php(254): Sabre\\DAV\\Server->invokeMethod(Object(Sabre\\HTTP\\Request), Object(Sabre\\HTTP\\Response))\n#6 \/var\/www\/html\/owncloud\/apps\/dav\/appinfo\/v1\/webdav.php(64): Sabre\\DAV\\Server->exec()\n#7 \/var\/www\/html\/owncloud\/remote.php(165): require_once(’\/var\/www\/html\/o…’)\n#8 {main}",“File”:"\/var\/www\/html\/owncloud\/apps\/dav\/lib\/Connector\/Sabre\/File.php",“Line”:227}"}
dmitry
April 11, 2019, 8:08pm
2
Dmitry,
Yes I have. This is my .user.ini:
upload_max_filesize=16G
post_max_size=16G
memory_limit=512M
mbstring.func_overload=0
always_populate_raw_post_data=-1
default_charset=‘UTF-8’
output_buffering=0
max_input_time 3600
max_execution_time 3600
I don’t see any issues with the Apache configuration…There aren’t any errors in the Apache log files.
Most of the configuration issues discussed in that link relate to files over 2GB, I can’t even get to 200MB.
i did the following search Search results for '"expected filesize" "got"' - ownCloud Central and found the following FAQ about this message:
Problem
I’m getting the following message in my data/owncloud.log:
"webdav","message":"Sabre_DAV_Exception_BadRequest: expected filesize 4734206 got 458752","level":4,"time":"2014-07-10T13:58:54+00:00"
"webdav","message":"Sabre_DAV_Exception_BadRequest: expected filesize 4734206 got 0","level":4,"time":"2014-07-10T13:58:54+00:00"}
Info
This can happen because of various reasons:
A bug in Apache https://github.com/owncloud/core/issues/9832#issuecomment-148380791
A too small “SSLRenegB…
Tom42,
Yes, I’ve tried those. PRoblem is, most of those solutions suggested are 4-5 years old and for many versions ago.
Seems file size upload issues are an ongoing issue with Owncloud. according to searches. Wonder why they can’t put a nail in this issue once and for all.
if i’m understanding the items listed in the FAQ as well as in the big upload documentation linked by @dmitry most upload problems concerning a specific file size are configuration problems or bugs in either Apache (or any other web server in use) or PHP. And i think such kind of items are also still valid even if 4-5 years old.
Not sure how they can do any fixes from ownCloud for such configuration issues or bugs the server admin needs to fix / reconfigure.
Taomyn
April 15, 2019, 6:55am
7
I’ve just started experiencing this after upgrading from 10.1.0.4 to 10.1.1.1 on my Fedora 29 box. I upload gigabyte files at least twice a week without a hitch now my Windows client is struggling with a 400Mb file and nothing else has changed. The log repeatedly shows:
{"reqId":"d0e222ba-9bfa-4658-a440-c3e940cd15bc","level":4,"time":"2019-04-15T06:41:19+00:00","remoteAddr":"192.168.1.1","user":"ferd","app":"webdav","method":"PUT","url":"\/remote.php\/dav\/uploads\/ferd\/3285899628\/00000013","message":"Exception: HTTP\/1.1 400 expected filesize 42471896 got 25722880: {\"Exception\":\"Sabre\\\\DAV\\\\Exception\\\\BadRequest\",\"Message\":\"expected filesize 42471896 got 25722880\",\"Code\":0,\"Trace\":\"#0 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(1130): OCA\\\\DAV\\\\Connector\\\\Sabre\\\\File->put(Resource id #536)\\n#1 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/CorePlugin.php(513): Sabre\\\\DAV\\\\Server->updateFile('uploads\\\/ferd\\\/32...', Resource id #536, NULL)\\n#2 [internal function]: Sabre\\\\DAV\\\\CorePlugin->httpPut(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#3 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/event\\\/lib\\\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\\n#4 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(479): Sabre\\\\Event\\\\EventEmitter->emit('method:PUT', Array)\\n#5 \\\/var\\\/www\\\/html\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(254): Sabre\\\\DAV\\\\Server->invokeMethod(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#6 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/dav\\\/lib\\\/Server.php(288): Sabre\\\\DAV\\\\Server->exec()\\n#7 \\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/dav\\\/appinfo\\\/v2\\\/remote.php(31): OCA\\\\DAV\\\\Server->exec()\\n#8 \\\/var\\\/www\\\/html\\\/owncloud\\\/remote.php(165): require_once('\\\/var\\\/www\\\/html\\\/o...')\\n#9 {main}\",\"File\":\"\\\/var\\\/www\\\/html\\\/owncloud\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/File.php\",\"Line\":228}"}
I followed the same procedure for years to upgrade making sure OC was in maintenance, stopping Apache, applying the update then running the upgrade before restarting Apache and disabling maintenance mode.
i’m not sure if this update is related. I have checked the changes between 10.1.0 and 10.1.1 (found on https://owncloud.org/changelog/server/ ) and it doesn’t look to me that any code related to uploading files where touched.
Could it be possible that some new configuration or PHP modules got updated / active during the update (e.g. due to a server restart where the changes/updates took place some days/weeks/months ago) which is now causing this issue?
Taomyn
April 15, 2019, 11:16am
9
It’s always possible and I normally check and apply updates each Monday and this has never happened before even when it’s needed to update ownCloud in the past - I always check what DNF wants to do before I let it go ahead, and as I saw that ownCloud came up I made sure to close it down as I mention before.
Smaller files are just fine, and when it hits a larger one I can keep forcing a sync and the client eventually uploads the entire thing. Downloads are fine.
This must be a Fedora 29 issue then, as I’m on Fedora 29 as well.
I also tried installing NextCloud 15 to see if that had the same issue, and it does. Exact same behavior.
So our commonality is Fedora 29 then at this time.
Taomyn
April 15, 2019, 1:36pm
11
Oh joy, so I wonder what’s been broken in F29 then?
On my system looks like PHP was upgraded to 7.2.17-1 amongst other things:
Install kernel-5.0.7-200.fc29.x86_64 @updates
Install kernel-core-5.0.7-200.fc29.x86_64 @updates
Install kernel-modules-5.0.7-200.fc29.x86_64 @updates
Upgrade owncloud-files-10.1.1-1.1.noarch @ce_10.1
Upgraded owncloud-files-10.1.0-1.1.noarch @@System
Upgrade containers-common-1:0.1.35-2.git404c5bd.fc29.x86_64 @updates
Upgraded containers-common-1:0.1.35-1.git404c5bd.fc29.x86_64 @@System
Upgrade fuse-2.9.9-2.fc29.x86_64 @updates
Upgraded fuse-2.9.9-1.fc29.x86_64 @@System
Upgrade fuse-common-3.4.2-2.fc29.x86_64 @updates
Upgraded fuse-common-3.4.2-1.fc29.x86_64 @@System
Upgrade fuse-libs-2.9.9-2.fc29.x86_64 @updates
Upgraded fuse-libs-2.9.9-1.fc29.x86_64 @@System
Upgrade iwl100-firmware-39.31.5.1-94.fc29.noarch @updates
Upgraded iwl100-firmware-39.31.5.1-93.fc29.noarch @@System
Upgrade iwl1000-firmware-1:39.31.5.1-94.fc29.noarch @updates
Upgraded iwl1000-firmware-1:39.31.5.1-93.fc29.noarch @@System
Upgrade iwl105-firmware-18.168.6.1-94.fc29.noarch @updates
Upgraded iwl105-firmware-18.168.6.1-93.fc29.noarch @@System
Upgrade iwl135-firmware-18.168.6.1-94.fc29.noarch @updates
Upgraded iwl135-firmware-18.168.6.1-93.fc29.noarch @@System
Upgrade iwl2000-firmware-18.168.6.1-94.fc29.noarch @updates
Upgraded iwl2000-firmware-18.168.6.1-93.fc29.noarch @@System
Upgrade iwl2030-firmware-18.168.6.1-94.fc29.noarch @updates
Upgraded iwl2030-firmware-18.168.6.1-93.fc29.noarch @@System
Upgrade iwl3160-firmware-1:25.30.13.0-94.fc29.noarch @updates
Upgraded iwl3160-firmware-1:25.30.13.0-93.fc29.noarch @@System
Upgrade iwl3945-firmware-15.32.2.9-94.fc29.noarch @updates
Upgraded iwl3945-firmware-15.32.2.9-93.fc29.noarch @@System
Upgrade iwl4965-firmware-228.61.2.24-94.fc29.noarch @updates
Upgraded iwl4965-firmware-228.61.2.24-93.fc29.noarch @@System
Upgrade iwl5000-firmware-8.83.5.1_1-94.fc29.noarch @updates
Upgrade iwl5150-firmware-8.24.2.2-94.fc29.noarch @updates
Upgraded iwl5150-firmware-8.24.2.2-93.fc29.noarch @@System
Upgrade iwl6000-firmware-9.221.4.1-94.fc29.noarch @updates
Upgraded iwl6000-firmware-9.221.4.1-93.fc29.noarch @@System
Upgrade iwl6000g2a-firmware-18.168.6.1-94.fc29.noarch @updates
Upgraded iwl6000g2a-firmware-18.168.6.1-93.fc29.noarch @@System
Upgrade iwl6000g2b-firmware-18.168.6.1-94.fc29.noarch @updates
Upgraded iwl6000g2b-firmware-18.168.6.1-93.fc29.noarch @@System
Upgrade iwl6050-firmware-41.28.5.1-94.fc29.noarch @updates
Upgraded iwl6050-firmware-41.28.5.1-93.fc29.noarch @@System
Upgrade iwl7260-firmware-1:25.30.13.0-94.fc29.noarch @updates
Upgraded iwl7260-firmware-1:25.30.13.0-93.fc29.noarch @@System
Upgrade kernel-headers-5.0.7-200.fc29.x86_64 @updates
Upgraded kernel-headers-5.0.6-200.fc29.x86_64 @@System
Upgrade kernel-tools-5.0.7-200.fc29.x86_64 @updates
Upgraded kernel-tools-5.0.6-200.fc29.x86_64 @@System
Upgrade kernel-tools-libs-5.0.7-200.fc29.x86_64 @updates
Upgraded kernel-tools-libs-5.0.6-200.fc29.x86_64 @@System
Upgrade libertas-usb8388-firmware-2:20190312-94.fc29.noarch @updates
Upgraded libertas-usb8388-firmware-2:20190213-93.git710963fe.fc29.noarch @@System
Upgrade linux-firmware-20190312-94.fc29.noarch @updates
Upgraded linux-firmware-20190213-93.git710963fe.fc29.noarch @@System
Upgrade linux-firmware-whence-20190312-94.fc29.noarch @updates
Upgraded linux-firmware-whence-20190213-93.git710963fe.fc29.noarch @@System
Upgrade pcre2-10.32-9.fc29.x86_64 @updates
Upgraded pcre2-10.32-8.fc29.x86_64 @@System
Upgrade perl-Data-Dumper-2.173-2.fc29.x86_64 @updates
Upgraded perl-Data-Dumper-2.173-1.fc29.x86_64 @@System
Upgrade php-7.2.17-1.fc29.x86_64 @updates
Upgraded php-7.2.16-1.fc29.x86_64 @@System
Upgrade php-cli-7.2.17-1.fc29.x86_64 @updates
Upgraded php-cli-7.2.16-1.fc29.x86_64 @@System
Upgrade php-common-7.2.17-1.fc29.x86_64 @updates
Upgraded php-common-7.2.16-1.fc29.x86_64 @@System
Upgrade php-devel-7.2.17-1.fc29.x86_64 @updates
Upgraded php-devel-7.2.16-1.fc29.x86_64 @@System
Upgrade php-fpm-7.2.17-1.fc29.x86_64 @updates
Upgraded php-fpm-7.2.16-1.fc29.x86_64 @@System
Upgrade php-gd-7.2.17-1.fc29.x86_64 @updates
Upgraded php-gd-7.2.16-1.fc29.x86_64 @@System
Upgrade php-intl-7.2.17-1.fc29.x86_64 @updates
Upgraded php-intl-7.2.16-1.fc29.x86_64 @@System
Upgrade php-json-7.2.17-1.fc29.x86_64 @updates
Upgraded php-json-7.2.16-1.fc29.x86_64 @@System
Upgrade php-ldap-7.2.17-1.fc29.x86_64 @updates
Upgraded php-ldap-7.2.16-1.fc29.x86_64 @@System
Upgrade php-mbstring-7.2.17-1.fc29.x86_64 @updates
Upgraded php-mbstring-7.2.16-1.fc29.x86_64 @@System
Upgrade php-mysqlnd-7.2.17-1.fc29.x86_64 @updates
Upgraded php-mysqlnd-7.2.16-1.fc29.x86_64 @@System
Upgrade php-pdo-7.2.17-1.fc29.x86_64 @updates
Upgraded php-pdo-7.2.16-1.fc29.x86_64 @@System
Upgrade php-process-7.2.17-1.fc29.x86_64 @updates
Upgraded php-process-7.2.16-1.fc29.x86_64 @@System
Upgrade php-xml-7.2.17-1.fc29.x86_64 @updates
Upgraded php-xml-7.2.16-1.fc29.x86_64 @@System
Upgrade python3-3.7.3-1.fc29.x86_64 @updates
Upgraded python3-3.7.2-5.fc29.x86_64 @@System
Upgrade python3-libs-3.7.3-1.fc29.x86_64 @updates
Upgraded python3-libs-3.7.2-5.fc29.x86_64 @@System
Upgrade python3-perf-5.0.7-200.fc29.x86_64 @updates
Upgraded python3-perf-5.0.6-200.fc29.x86_64 @@System
Upgrade skopeo-1:0.1.35-2.git404c5bd.fc29.x86_64 @updates
Upgraded skopeo-1:0.1.35-1.git404c5bd.fc29.x86_64 @@System
Upgrade vim-minimal-2:8.1.1137-1.fc29.x86_64 @updates
Upgraded vim-minimal-2:8.1.1099-1.fc29.x86_64 @@System
Removed kernel-5.0.4-200.fc29.x86_64 @@System
Removed kernel-core-5.0.4-200.fc29.x86_64 @@System
Removed kernel-modules-5.0.4-200.fc29.x86_64 @@System
Taomyn
April 23, 2019, 6:29am
12
@Virtual have you come across a way to fix this? I’ve been looking and checked for new updates to Fedora and nothing so far.
Nothing. I’ve searched and asked on several social media forums and not a single response.
Given that Fedora 29 has been around for almost 6 months now, I’m surprised this hasn’t come up before.
Taomyn
April 24, 2019, 6:31am
14
I suspect it’s a recent update to either Apache or PHP, so I’m checking daily for updates to see if anything gets applied and then test ownCloud.
