Carddav problem apple contacts - Owncloud 10.0.8
Carddav does work well from android via davdroid. But apple contact applications makes a connection to the server without errors, but no address books nor contacts are shown. There is just one default contact addressbook in OwnCloud.
Just an empty addressbook in Apple
I could connect Apple contacts to https://myserver.nl/owncloud/remote.php/dav
With the username en password.
But then no contacts are shown.
Does anyone know where the solution for this problem is? I think it has something to do with the address books.
From Hosting provider. Linux - Apache.
PHP version: 7.0
ownCloud version: 10.0.8
Client version: 11.0
Operating system: Apple OsX 10.13.5
OS language: Dutch
https://doc.owncloud.org/server/latest/user_manual/pim/sync_osx.html
https://doc.owncloud.org/server/latest/user_manual/pim/sync_ios.html
Thank you for answer DeepDiver1975.
Since I have OSX 10.13.5 the situation is a little different. Contacts in OSX does connect to carddav, but does not show addressbooks, nor contacts.
In 10.13.5 the folder /Users/YOUR_USERNAME/Library/Application Support/AddressBook/Sources. is different. There is no file named: Configuration.plist The files in there are kind off database files now. with extensions: .abcddb, .abcddb-shm and .abcddb-wal.
Do you have other tips?
I have very limited knowledge about OSX - sorry. The only thing I can tell is that from a pure CalDAV point of view ownCloud is behaving correctly …
Hi Bart,
under OS X 10.7 and newer there is no need to configure the configration.plist.
Are you sure, that you are using the right iOS/OS X CardDAV address in the Apple Contacts App?
Normally it looks like this:
https://www.myserver.nl/owncloud/remote.php/dav/principals/users/myusername/
Thank you Haio.
I tried this principals link too. although it is different from owncloud’s suggestion: dav/addressbooks/users/username.
Still no contacts shown. :frowning:
HI BART,
I JUST SOLVED THE SAME PROBLEM:
Instead of trying: /owncloud/remote.php/dav/principals/users/myusername/
I left the “owncloud” and used:
and it worked fine - for whatever reason - I am using a hosted Owncloud instance…
Hope this is helpful for you as well…
Hubert
Please note that it seems that OSX is later versions is a bit stricter with transmitting the credentials.
SSL is a must have as well as a valid certificate chain.
