Changes in data folder through samba are not synced
I have samba sharing the data folder on the server. Directly modifying files in the data folder through samba in the server are not synced to the clients. is there a way to make the data folder fully monitered and any changes in this folder will be synced to all the clients?
  1. On the server share the owncloud data folder through Samba
  2. Write/delete file in the data folder through Samba
  3. Files that are modified won’t be synced by owncloud
The reason i share the data folder of owncloud on the server is because i want to directly modify the files through samba without installing the owncloud client program for the PC at home.
The server won’t sync the files that are modified through samba
Operating system: freenas portjail/freebsd
Web server: lighttpd
Database: sqlite
PHP version: 5.6.27
ownCloud version (see ownCloud admin page): 9.1 stable
Updated from an older ownCloud or fresh install:fresh install
Special configuration (external storage, external authentication, reverse proxy, server-side-encryption): no
Integrity status for oC9+
no error
See:
