Greetings.
Im installed custom theme from guide https://doc.owncloud.com/server/developer_manual/core/theming.html
All right, but I have trouble with folder icon. I see, my folder’s icon taken from path: /core/img/filetypes/folder.svg
If i trying create custom folder.svg icon on /apps/mynewtheme/core/img/filetypes folder, and create custom files.php(as original /apps/files/css/files.php exactly change path for taking:
.nav-icon-files {
background-image: url("/apps/mynewtheme/apps/files/img/folder.svg");
), anyway i see than my icon taken from path /core/img/filetypes/folder.svg.
I saw manual about changing icons for filetypes, but i dont see what file i need change for customize my folders icon.
P.S.
Earlier I tryed swap original file on path /core/img/filetypes and its work well, but i saw hash trouble message on admin panel, so i wanna to do proper installation without “botch”.
Changing default icons and path for that
Icons and path saved default
Operating system: Ububtu server 19.10
Web server: apache2
Database: Mariadb last
PHP version: 7+ last
ownCloud version: 10.3.0.4
**Updated from an older ownCloud or fresh install:**fresh install
Where did you install ownCloud from: offical site
The content of config/config.php: dont need
Are you using encryption: yes
I don’t know exactly what you’re doing wrong but the way over the Files.php seems wrong to me.
What I would do is simply overwrite the icons with CSS. The changed folder image files should be under apps/YOURTHEME/core/img/filetypes. Then the following is written to the file apps/YOURTHEME/core/css/styles.css for the icon you wanted to replace according to the description.
