09.05.2018 12:55:12,Patch/2018/2018.05.16/Document.docx, ownCloud,Server hat “400 Bad Request” auf “PUT https://owncloud.cp-rz.de/remote.php/dav/files/User/Ordner/2018/2018.05.16/Document.docx” geantwortet (The computed checksum does not match the one received from the client.)(Übersprungen aufgrund des früheren Fehler,s erneuter Versuch in 14 Sekunden)
The error only appeared on terminalserver. Strange is that web- and clientupload fails. When i use the DC(Windows Server 2016) or a Windows 10 Client everything works fine.
Error webupload: expercted filesize 11672 got 0
Operating system: Windows 2016 Standard Terminalserver
ownCloud version: V.2.4.1 (build 9270)
I posponed this update of the server … there is only one client with this problem… the oders work as expected… will have to wait for a new release of the windows client.
Installed the same version, same instalation steps for other client, works woderfully … it is driving me crazy … must be something from the windows client or the Client OS …
