I have problem with downloading two files using desktop client. Client restarts downloading again and again and after finishing in tab "not synced" I have information
"25.05.2017 10:23:28, wymiana/VID_20170207_170412.mp4, ownCloud,The downloaded file does not match the checksum, it will be resumed."
There are two files of size about 100MB and 800MB, so it is a bit annoying. On other clients I have no problem. Is there a possibility to force client not to delete those files after downloading so I can check checksums manually using just md5sum command? I'd like to dig a bit end prepare bug report after that.
What's more, I have no problem with those files on other machines. On the affected machine I have no problem with other files.
Affected machine is Debian 8.0 installed in VirtualBox hosted in Win 8.1.
Regards
Mirek
