Dear all,
We currently use ownCloud on a remote dedicated server, to keep our data in a different physical place in case the office burns (which actually happened two months ago, zero data loss, phew).
However there still is the question of security, because dedicated hosting admins could in theory access the data. Plus sometimes, the internet connection is down/poor.
So I am thinking in having the owncloud server at office, and convert the remote dedicated server to an encrypted external storage.
1) In this case, is the data mirrored on the local owncloud server, so that when the internet connection is down, we can still use the local server to sync, and he will update the remote one as soon as the internet connection is back?
2) What happens if the local server is destroyed, can I re-mount the remote storage on a new server or is the key lost? (In other words, is there any simple way to save the key and use it later?)
3) What is the best protocol for this? I can basically install any linux server on the dedicated remote server.
Thanks!
