Thanks for the great app for virus scanning of files: files_antivirus
It was a very good idea to implement.
I would like to get a clarification regarding settings for this app and how it interacts with clamav.
Settings that i would like to clarify:
av_max_file_size - If i got it right this value should tell the app from 0 bytes up to what size the app should pass files to clamav for virus scan? Meaning: Any file bigger than the value set in this attribute is not scanned for viruses but it is transparently allowed to be stored right?
av_scan_background - Is this value indicating that from time to time files_antivirus calls for clamav to do background scan of all the files in the owncloud data directory? If so how is the time interval between these background scans determined?
Thank you for the info.
Actually i did checked your documentation but it was very brief concerning these parameters.
I am debugging a very intermittent issue where sometimes i find my owncloud storage server completely saturated with hundreds of clamscan processes and it runs out of RAM and SWAP space.
I have a suspicion that this is caused by owncloud background cron job antivirus scans which i had previously enabled by default value and i had no limit to file size scan. I have very many files stored there.
In any case i had disabled these scans and set a filesize limit. If this would not help, i would raise a separate topic with detail issue description.
And once again thank you for this great antivirus integration functionality.
