I have found this error in the owncloud log, and it happens quite often. How could I configure properly not to get this error?
{“reqId”:“fklsjafkldjsakfljdsa”,“level”:3,“time”:“June 08, 2021 04:30:02”,“remoteAddr”:“”,“user”:“–”,“app”:“core”,“method”:“–”,“url”:“–”,“message”:“Exception: {"Exception":"OCP\\AppFramework\\QueryException","Message":"Could not resolve OCA\\Federation\\SyncJob! Class OCA\\Federation\\SyncJob does not exist","Code":0,"Trace":"#0 \/var\/www\/owncloud\/lib\/private\/AppFramework\/Utility\/SimpleContainer.php(110): OC\\AppFramework\\Utility\\SimpleContainer->resolve()\n#1 \/var\/www\/owncloud\/lib\/private\/ServerContainer.php(86): OC\\AppFramework\\Utility\\SimpleContainer->query()\n#2 \/var\/www\/owncloud\/lib\/private\/BackgroundJob\/JobList.php(253): OC\\ServerContainer->query()\n#3 \/var\/www\/owncloud\/lib\/private\/BackgroundJob\/JobList.php(209): OC\\BackgroundJob\\JobList->buildJob()\n#4 \/var\/www\/owncloud\/core\/Command\/System\/Cron.php(114): OC\\BackgroundJob\\JobList->getNext()\n#5 \/var\/www\/owncloud\/lib\/composer\/symfony\/console\/Command\/Command.php(255): OC\\Core\\Command\\System\\Cron->execute()\n#6 \/var\/www\/owncloud\/lib\/composer\/symfony\/console\/Application.php(1009): Symfony\\Component\\Console\\Command\\Command->run()\n#7 \/var\/www\/owncloud\/lib\/composer\/symfony\/console\/Application.php(273): Symfony\\Component\\Console\\Application->doRunCommand()\n#8 \/var\/www\/owncloud\/lib\/composer\/symfony\/console\/Application.php(149): Symfony\\Component\\Console\\Application->doRun()\n#9 \/var\/www\/owncloud\/lib\/private\/Console\/Application.php(165): Symfony\\Component\\Console\\Application->run()\n#10 \/var\/www\/owncloud\/console.php(116): OC\\Console\\Application->run()\n#11 \/var\/www\/owncloud\/occ(11): require_once(‘\/var\/www\/ownclo…’)\n#12 {main}","File":"\/var\/www\/owncloud\/lib\/private\/AppFramework\/Utility\/SimpleContainer.php","Line":96}”}
Ubuntu 18.04.5 LTS
Apache/2.4.29 (Ubuntu)
10.5.10-MariaDB-1:10.5.10+maria~bionic mariadb.org binary distribution
PHP 7.4.20 (cli) (built: Jun 4 2021 21:24:37) ( NTS )
10.7.0.4
Yes, updated.
Enabled:
- activity:
- Version: 2.6.0
- calendar:
- Version: 1.6.4
- Path: /var/www/owncloud/apps-external/calendar
- comments:
- Version: 0.3.0
- configreport:
- Version: 0.2.0
- contacts:
- Version: 1.5.5
- Path: /var/www/owncloud/apps-external/contacts
- dav:
- Version: 0.6.0
- federatedfilesharing:
- Version: 0.5.0
- files:
- Version: 1.5.2
- files_antivirus:
- Version: 1.0.0
- Path: /var/www/owncloud/apps-external/files_antivirus
- files_external:
- Version: 0.7.1
- files_mediaviewer:
- Version: 1.0.4
- files_pdfviewer:
- Version: 0.12.1
- Path: /var/www/owncloud/apps-external/files_pdfviewer
- files_sharing:
- Version: 0.14.0
- files_texteditor:
- Version: 2.3.1
- Path: /var/www/owncloud/apps-external/files_texteditor
- files_trashbin:
- Version: 0.9.1
- files_versions:
- Version: 1.3.0
- firstrunwizard:
- Version: 1.2.0
- market:
- Version: 0.6.0
- notifications:
- Version: 0.5.2
- provisioning_api:
- Version: 0.5.0
- systemtags:
- Version: 0.3.0
- templateeditor:
- Version: 0.4.0
- Path: /var/www/owncloud/apps/templateeditor
- theme-sintas:
- Version: 1.0.0
- Path: /var/www/owncloud/apps-external/theme-sintas
- updatenotification:
- Version: 0.2.1
Disabled:
- admin_audit:
- Path: /var/www/owncloud/apps/admin_audit
- announcementcenter:
- Path: /var/www/owncloud/apps/announcementcenter
- customgroups:
- Path: /var/www/owncloud/apps/customgroups
- encryption:
- enterprise_key:
- Path: /var/www/owncloud/apps/enterprise_key
- external:
- federation:
- files_classifier:
- Path: /var/www/owncloud/apps/files_classifier
- files_external_dropbox:
- Path: /var/www/owncloud/apps/files_external_dropbox
- files_external_ftp:
- Path: /var/www/owncloud/apps/files_external_ftp
- files_ldap_home:
- Path: /var/www/owncloud/apps/files_ldap_home
- files_lifecycle:
- Path: /var/www/owncloud/apps/files_lifecycle
- firewall:
- Path: /var/www/owncloud/apps/firewall
- graphapi:
- Path: /var/www/owncloud/apps/graphapi
- guests:
- Path: /var/www/owncloud/apps/guests
- metrics:
- Path: /var/www/owncloud/apps/metrics
- oauth2:
- Path: /var/www/owncloud/apps/oauth2
- openidconnect:
- Path: /var/www/owncloud/apps/openidconnect
- password_policy:
- Path: /var/www/owncloud/apps/password_policy
- ransomware_protection:
- Path: /var/www/owncloud/apps/ransomware_protection
- sharepoint:
- Path: /var/www/owncloud/apps/sharepoint
- systemtags_management:
- Path: /var/www/owncloud/apps/systemtags_management
- theme-enterprise:
- Path: /var/www/owncloud/apps/theme-enterprise
- user_external:
- user_ldap:
- Path: /var/www/owncloud/apps/user_ldap
- user_shibboleth:
- Path: /var/www/owncloud/apps/user_shibboleth
- windows_network_drive:
- Path: /var/www/owncloud/apps/windows_network_drive
- wopi:
- Path: /var/www/owncloud/apps/wopi
- workflow:
- Path: /var/www/owncloud/apps/workflow
