Click on "Updater" results in 405 [reason phrase] Method Not Allowed
  1. Login as administrator in Owncloud version 10.5.0.10
  2. Go to settings -> Administration -> General
  3. Click on “Updater aufrufen” in the section “Updater”
The update process should start.
I get a blank page with the following text:
Client error response [url] https://owncloud.example.com/index.php/occ/config:list [status code] 405 [reason phrase] Method Not Allowed
Operating system: Ubuntu 18.04.5 LTS
Web server: Apache/2.4.29 (Ubuntu)
Database: MySQL 5.7.32-0ubuntu0.18.04.1
PHP version: PHP-FPM 7.2+60ubuntu1
ownCloud version: 10.5.0.10
Where did you install ownCloud from: From a zip file
Signing status (ownCloud 9.0 and above): Don’t know what that means
    "config": {
        "trusted_domains": [
            "swcloud"
        "datadirectory": "\/home\/owncloud\/owncloud\/data",
        "overwrite.cli.url": "https:\/\/***REMOVED SENSITIVE VALUE***",
        "remember_login_cooki_lifetime": 2851200,
        "session_lifetime": 86400,
        "session_keepalive": true,
        "version": "10.5.0.10",
        "dbtype": "mysql",
        "dbname": "cloud",
        "dbhost": "localhost",
        "dbtableprefix": "oc_",
        "logtimezone": "UTC",
        "installed": true,
        "instanceid": "***REMOVED SENSITIVE VALUE***",
        "loglevel": 2,
        "mail_smtpmode": "smtp",
        "mail_smtpsecure": "tls",
        "mail_smtpauthtype": "PLAIN",
        "mail_smtpport": "587",
        "mail_smtpauth": 1,
        "maintenance": false,
        "htaccess.RewriteBase": "\/",
        "appstore.experimental.enabled": true,
        "theme": "",
        "filelocking.enabled": "true",
        "memcache.local": "\\OC\\Memcache\\Redis",
        "activity_expire_days": 120,
        "redis": {
            "host": "\/var\/run\/redis\/redis-server.sock",
            "port": 0
        "updater.secret": "***REMOVED SENSITIVE VALUE***"
Enabled:
  - activity: 2.6.0
  - calendar: 1.6.4
  - configreport: 0.2.0
  - contacts: 1.5.5
  - dav: 0.6.0
  - federatedfilesharing: 0.5.0
  - federation: 0.1.0
  - files: 1.5.2
  - files_clipboard: 1.0.2
  - files_external: 0.7.1
  - files_mediaviewer: 1.0.3
  - files_pdfviewer: 0.11.2
  - files_sharing: 0.13.0
  - files_trashbin: 0.9.1
  - files_versions: 1.3.0
  - firstrunwizard: 1.2.0
  - gallery: 16.1.1
  - impersonate: 0.5.0
  - market: 0.6.0
  - notifications: 0.5.2
  - provisioning_api: 0.5.0
  - qownnotesapi: 19.1.0
  - tasks: 0.9.7
  - templateeditor: 0.4.0
  - updatenotification: 0.2.1
Disabled:
  - admin_audit
  - announcementcenter
  - comments
  - customgroups
  - encryption
  - enterprise_key
  - external
  - files_antivirus
  - files_classifier
  - files_external_dropbox
  - files_external_ftp
  - files_ldap_home
  - files_texteditor
  - firewall
  - guests
  - oauth2
  - password_policy
  - ransomware_protection
  - sharepoint
  - systemtags
  - systemtags_management
  - theme-enterprise
  - twofactor_totp
  - user_external
  - user_ldap
  - user_shibboleth
  - windows_network_drive
  - wopi
  - workflow
Are you using external storage, if yes which one: sftp
Are you using encryption: no
Browser: Mozilla Firefox for Ubuntu 84.0.2 (64-Bit)
Operating system: Ubuntu 20.04.1 LTS
10.100.20.1 - - [15/Jan/2021:18:45:39 +0100] "GET /apps/updatenotification/credentials HTTP/1.1" 200 782 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:84.0) Gecko/20100101 Firefox/84.0"
10.100.20.1 - - [15/Jan/2021:18:45:39 +0100] "GET /index.php/occ/config:list HTTP/1.1" 405 974 "-" "Guzzle/5.3.1 curl/7.58.0 PHP/7.2.24-0ubuntu0.18.04.7"
10.100.20.1 - - [15/Jan/2021:18:45:39 +0100] "POST /updater/ HTTP/1.1" 200 496 "-" "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:84.0) Gecko/20100101 Firefox/84.0"
I can not add 180MB of log file here.
Is this really necessary?
Would be nice to get some help. I want to upgrade a production system and with these errors it is not possible.
Hi NicolasGoeddel,
unfortunately you did not write FROM which ownCloud version you upgraded to 10.5.0.10. If this was an older version, did you follow the upgrade path? See https://doc.owncloud.com/server/admin_manual/maintenance/upgrade.html
When not upgrading with the suggested path you can be sure to run into troubles.
Anyway, I personally discourage using the web updater, I’d recommend to perform a manual upgrade, see the docs: https://doc.owncloud.com/server/admin_manual/maintenance/manual_upgrade.html
The version before 10.5.0.10 was 10.4.0. I still have the tarball of the old version as a backup. The version before 10.4.0 was 10.1.1 if I am right.
Thank you. So you are safe upgrading to any 10.x release.
I’d suggest to perform a manual upgrade. Let us know if you run into difficulties.
It might work only through a localhost connection. You could also try with the ip address of the server. I guess updating from an external host could be considered as a security risk, so it isn’t allowed.
Anyway, I’d recommend a manual upgrade too.
