Client should connect and sync as normal after PC restart.
Client will fail to login to sync after initial setup and sync on new install.
After researt, a “No Connection” message is flashed briefly in the client window.
Web Interface works fine.
- Install client via apt-get on Ubuntu 18.04
- Setup as normal, allow to sync.
- Restart PC
Operating system: CentOS 7
Web server: Apache2
Database: MariaDB
PHP version:7.0.23
ownCloud version: 10.0.3.3
Client version: 2.4.1
Operating system: Ubuntu 18.04
OS language: English
Qt version used by client package (Linux only, see also Settings dialog): ??
Client package (From ownCloud or distro) (Linux only): 2.4.1
Installation path of client: ??
logs.
- Client logfile: Output of
owncloud --logwindow
orowncloud --logfile log.txt
(On Windows usingcmd.exe
, you might need to firstcd
into the ownCloud directory)
(See also http://doc.owncloud.org/desktop/2.2/troubleshooting.html#client-logfile )
BLANK
- Web server error log:
BLANK
- Server logfile: ownCloud log (data/owncloud.log):
NOTE: None of these time stamps match me trying to reconnect this morning.
“reqId”:“uCaOTO6bmwU7Ek1RbRVx”,“level”:3,“time”:“2019-01-27T20:19:44+00:00”,“remoteAddr”:“108.197.13.110”,“user”:“user”,“app”:“PHP”,“method”:“GET”,“url”:"/index.php/settings/admin?sectionid=general",“message”:“opendir(/opt/bitnami/apps/owncloud/htdocs/themes): failed to open dir: No such file or directory at /opt/bitnami/apps/owncloud/htdocs/apps/templateeditor/lib/mailtemplate.php#155”}
{“reqId”:“TaYruH4SWspXqgk0sDFi”,“level”:3,“time”:“2019-01-27T20:20:02+00:00”,“remoteAddr”:“108.197.13.110”,“user”:“user”,“app”:“PHP”,“method”:“GET”,“url”:"/index.php/settings/admin?sectionid=general",“message”:“opendir(/opt[REMOVED - - [28/Jan/2019:13:14:19 +0000] “GET /ocs/v2.php/apps/notifications/api/v1/notifications?format=json HTTP/1.1” 200 108
[REMOVED] - - [28/Jan/2019:13:14:49 +0000] “GET /ocs/v2.php/apps/notifications/api/v1/notifications?format=json HTTP/1.1” 200 108/bitnami/apps/owncloud/htdocs/themes): failed to open dir: No such file or directory at /opt/bitnami/apps/owncloud/htdocs/apps/templateeditor/lib/mailtemplate.php#155”}
{“reqId”:“UQ4ye581J5ilz8lqQp6W”,“level”:2,“time”:“2019-01-27T22:19:52+00:00”,“remoteAddr”:“REMOVED”,“user”:"–",“app”:“core”,“method”:“POST”,“url”:"/index.php/login?redirect_url=%252Findex.php%252Fsettings%252Fadmin%253Fsectionid%253Dapps",“message”:“Login failed: ‘user’ (Remote IP: REMOVED’)”}
{“reqId”:“vFVy4yTo9iHsi5BhBCfS”,“level”:3,“time”:“2019-01-27T22:20:14+00:00”,“remoteAddr”:“REMOVED”,“user”:“user”,“app”:“PHP”,“method”:“GET”,“url”:"/index.php/settings/admin?sectionid=general",“message”:“opendir(/opt/bitnami/apps/owncloud/htdocs/themes): failed to open dir: No such file or directory at /opt/bitnami/apps/owncloud/htdocs/apps/templateeditor/lib/mailtemplate.php#155”}
{“reqId”:“jxaMCjVxYSlfcDzJWKyZ”,“level”:3,“time”:“2019-01-27T22:22:56+00:00”,“remoteAddr”:“REMOVED”,“user”:“user”,“app”:“PHP”,“method”:“GET”,“url”:"/index.php/settings/admin?sectionid=general",“message”:“opendir(/opt/bitnami/apps/owncloud/htdocs/themes): failed to open dir: No such file or directory at /opt/bitnami/apps/owncloud/htdocs/apps/templateeditor/lib/mailtemplate.php#155”}
{“reqId”:“uyFZ15GplRSdoP11tnrG”,“level”:2,“time”:“2019-01-28T12:27:01+00:00”,“remoteAddr”:“REMOVED”,“user”:"–",“app”:“core”,“method”:“PROPFIND”,“url”:"/remote.php/webdav/",“message”:“Login failed: ‘fedorauser24’ (Remote IP: ‘REMOVED’)”}
