Client Login not possible (HTTP/1.1" 401 306)
Hi!
I have a problem login via Webdav. After installing OwnCloud 9.1.0 it’s not possible to access the cloud using the windows client. Web interfaces is working as expected.
  1. Start windows client, enter URL, enter user and pw
  2. Connection closed
Client version: 2.2.3
Client operating system: Windows 7 HP x64
Operating system: Cloudlinux 7.2, LVE enabled, CageFS enabled + cPanel
Web server: Apache 2.4 using CGI/FastCGI
Database: MariaDB 10.0
PHP version: 7.0.9
ownCloud version: 9.1.0, new installed
Client
09-06 18:41:50:197 0x72beb68 unknown: ERRORING CURRENT QHttpNetworkReply(0x72ba970) QUrl( “https://example.com/owncloud/remote.php/webdav/” )
09-06 18:41:50:199 0x7eefd8 OCC::AbstractNetworkJob::slotFinished: void OCC::AbstractNetworkJob::slotFinished() 2 “Verbindung beendet” QVariant(Invalid)
09-06 18:41:50:199 0x7eefd8 OCC::PropfindJob::finished: PROPFIND request not successful, http result code is 0 “”
Apache
[06/Sep/2016:18:41:24 +0200] “GET /owncloud/status.php HTTP/1.1” 200 96 “-” “Mozilla/5.0 (Windows) mirall/2.2.3 (build 6307)”
[06/Sep/2016:18:41:24 +0200] “GET /owncloud/remote.php/webdav/ HTTP/1.1” 401 306 “-” “Mozilla/5.0 (Windows) mirall/2.2.3 (build 6307)”
[06/Sep/2016:18:41:42 +0200] “PROPFIND /owncloud/remote.php/webdav/ HTTP/1.1” 401 306 “-” “Mozilla/5.0 (Windows) mirall/2.2.3 (build 6307)”
CarotDAV
The remote server returned an error: (405) Method Not Allowed.
at Rei.Fs.Webdav.WebdavFs.GetResponse(HttpWebRequest request, Boolean notreqstream)
at Rei.Fs.Webdav.WebdavFs.GetResourceOptions(Uri target)
at Rei.Fs.Webdav.ConnectionTestForm.Check()
Attemps
  • disable mod_security
  • disable mod_deflate
  • checked everything in ownCloud Central
  • tried to connent with CarrotDAV
  • /owncloud/status.php & /owncloud/remote.php/webdav/ are accessible with browser
So I am at my wit’s end…what could it be?
Thanks in advance for your help!
try to switch to either Apache + mod_php (officially supported) or nginx + php-fpm (community supported) which shouldn’t show this issue.
For CGI/FastCGI you’re mostly on your own when facing such webserver issues.
