I’m guessing the Windows client should sync new files without having to have the owncloud website open. The files I’m trying to sync is “external storage” located in a local directory on the server but outside the webserver document root.
Nothing is synced no matter how long I wait. The owncloud windows client shows a green check and no errors. If I open a web browser and login to my owncloud, a pop-up immediately appears and all changes are synced. If I navigate off the owncloud site then sycing stops.
- Install and configure client.
- Start client.
- Drink a beer and watching nothing happen.
- Log in to the owncloud web portal. Watch files sync.
Operating system: Centos 8
Web server: Centos 8 hppd.
Database: mysql
PHP version: Not sure
ownCloud version: Stable version installed two weeks ago.
Client version: 2.6.3 (build 13551)
Operating system: Windows 10 pro
OS language: English
Installation path of client:
logs.
Client logfile: Output of
owncloud --logwindoworowncloud --logfile log.txt
(On Windows usingcmd.exe, you might need to firstcdinto the ownCloud directory)
(See also http://doc.owncloud.org/desktop/2.2/troubleshooting.html#client-logfile ) -
Web server error log:
