Client Synchronization
I need to know, whether it is possible to schedule sync for every 5 minutes for each user, consider we have more than 100 users, we need to schedule sync by allocating 5 minutes per user. please help.
Yes, this is possible with the command line client and a script/application steering this. However the desktop client of course is capable to work in parallel …
can i get any documentation for this, using command line and script/application.
And Shall i know, how can i delay the synch ?
You can start it it as you like. Did you read the documentation? Basically start a sync run at a time … for a specific user.
Yes i read, but i couldn’t find solution to schedule in that document. Can you say the steps to do this. or which step to follow in the documentation ?
