Client won't start with sqlite prepare error
Hi guys,
I’m new to the forum but not to owncloud in general. I have a problem with the sync client. It simply won’t start. The logfile says the following (last few lines):
09-20 22:46:32:808 0x162f460 void OCC::SyncJournalDb::commitInternal(const QString&, bool) Transaction commit  "checkConnect" and starting new transaction
09-20 22:46:32:808 0x162f460 Columns in the current journal:  ("phash", "pathlen", "path", "inode", "uid", "gid", "mode", "modtime", "type", "md5", "fileid", "remotePerm", "filesize", "ignoredChildrenRemote", "contentChecksum", "contentChecksumTypeId")
09-20 22:46:32:808 0x162f460 void OCC::SyncJournalDb::commitInternal(const QString&, bool) Transaction commit  "update database structure: add inode index" and starting new transaction
09-20 22:46:32:808 0x162f460 void OCC::SyncJournalDb::commitInternal(const QString&, bool) Transaction commit  "update database structure: add path index" and starting new transaction
09-20 22:46:32:808 0x162f460 Columns in the current journal:  ("path", "lastTryEtag", "lastTryModtime", "retrycount", "errorstring", "lastTryTime", "ignoreDuration", "renameTarget")
09-20 22:46:32:809 0x162f460 void OCC::SyncJournalDb::commitInternal(const QString&, bool) Transaction commit  "checkConnect End"
09-20 22:46:32:811 0x162f460 Sqlite prepare statement error: "unable to open database file" in "PRAGMA quick_check;"
09-20 22:46:32:811 0x162f460 ASSERT: "!"SQLITE Prepare error"" in file /usr/src/packages/BUILD/src/libsync/ownsql.cpp, line 215
  1. Start the client
Client comes up and begins to sync or show the configuration screen
Nothing happens.
Client version: 2.2.3
Client operating system: Xubuntu 14.04 LTS 64 Bit
Operating system: Ubuntu 16.04 LTS 64 Bit
Web server: Apache2
PHP version: 7.0.8-0ubuntu0.16.04.2
Thanks in advance for any help!
Regards,
siegmund
@dragotin @guruz can you help?
The log say “unable to open database file”
Whch means maybe the database file is corrupted.
The database file is named .csync_journal.db in your sync folder. (it’s an hidden file.)
I don’t exactly what is corrupted, or how.
Moving this file away will cause a full resync and will probably solve your problem if you look for a quick fix. But this might cause some downloads and some conflict files.
Thanks @ogoffart for the hint!
I checked my synced folders and moved the database files while I noticed that my file system somehow was broken. There where two files ( “.csync_journal.db-shm”, “.csync_journal.db-wal” ) that seemed to be broken (Ubuntu gave me an Input/Output-Error on these).
After executing chkdsk on windows (it was a ntfs partition) everything is fine now.
So I guess this wasn’t directly related to/the fault of owncloud, was it?
