- Settings
- Updater
- Start
Updater should either fail at “Checking system” or run to completion.
Updater runs as far as “Updating core : Copying the application user_external” then hangs for over an hour. Alongside “Updating core” is the circling icon. Below “Updating apps” is highlighted in rad with a warning icon, and the message “undefined” below.
Linux: AlmaLinux 8.6 (Sky Tiger)
Apache/2.4.37
sqlite3 3.26.0
10.8.0.4 → 10.9.1
Updating in progress
Online, via updater.
$ php occ config:list system
This version of ownCloud requires at least PHP 7.3.0
You are currently running PHP 7.2.24. Please update your PHP version.
not yet
no
no
Firefox
AlmaLinux
This looks like “Checking system” should have picked up on the PHP (based on the occ config:list system
command). I thought the PHP upgrade was only needed for 10.10.X
Can I safely abort the installation or do I need to go back to backups?
