Code integrity check error
Hi guys I have a problem with the integrity check.
I don’t understand rootbash and userbash?
Results
  • core
    • EXTRA_FILE
      • rootbash
      • userbash
Raw output
Array
[core] => Array
[EXTRA_FILE] => Array
[rootbash] => Array
[expected] =>
[current] => c78fc8ba75e0ddd527f81697ace0429b95439e0eba9e2d57c0fcf40c915d45239c4b54b1b6e324d9f361951d947adcc8d52372f40a737a21f4dc5fc1815f9f37
                [userbash] => Array
                        [expected] =>
                        [current] => 00e1d9f7d081bf0bf503f9afd93d2cdef5f4eb89bc5e9e9078c3bc39377f875559cd5f38d649403095961a2afa71fb8b92347ecbad684937ff0cd69d17df790c
[/code]
The integrity message contains a link to the documentation [1] explaining the needed steps how to fix this. Is there something missing or not understandable in that documentation?
[1] ownCloud Documentation Overview
When doing such short posts its not possible to help here as no one can guess what steps you have done to fix this.
The documentation contains all needed information how to fix these message. Please follow it step by step to delete the mentioned files and doing the rescan as also explained in the documentation.
You probably just have missed one step or have not deleted / fixed all files.
I don’t need any information as i won’t continue to help here (IMHO all infos where provided to fix this issue).
Is also not clear if you have exactly the same problem as the original poster so you’re might be also just wrong in this thread.
Please create a new thread as your issue is then unrelated to the one of the original poster.
