Code integrity check failed
Hey!
I have today a new Server installed - so its a fresh install, installed with Linux Distribution Packages
I Use Debian 10, PHP7.3, Apache2, Owncloud 10.5, MariaDB latest Version.
I have a Problem, with a Code integrity check:
Technical information
them.
Results
- twofactor_totp
	- FILE_MISSING
		- vendor/khanamiryan/qrcode-detector-decoder/tests/QrReaderTest.php~
Raw output
Array
    [twofactor_totp] => Array
            [FILE_MISSING] => Array
                    [vendor/khanamiryan/qrcode-detector-decoder/tests/QrReaderTest.php~] => Array
                            [expected] => 05a20a084562bf6a61b9395635b2baa2fa0a3eb443d25027997cc3e83c71d5d1b3dfedd280149071db11121dc1ad30014e4b9778652808c2703b6d642b3b9a68
                            [current] =>
What i have to do?
Read the message:
In the totp app is a file missing:
I had a look in the repos and the file should be there.
Edit: I didn’t tell you what to do. Re-download and/or re-extract your installation archive and place the missing file in the path specified.
Obviously a look in the docs would have helped as well:
:wink:
Thanks :slightly_smiling_face:
