Code integrity problem
i just make a fresh install of owncloud 9.1.3 on centos 7, but problem come after that, owncloud warn me about a code integrity problem, and when i take a look to the list of files, it saying me that all applications and files are in default
I join the complete list at this post :
Results
  • core
  • EXCEPTION
  • OC\IntegrityCheck\Exceptions\InvalidSignatureException
  • Signature could not get verified.
  • activity
  • EXCEPTION
  • comments
  • EXCEPTION
  • dav
  • EXCEPTION
  • encryption
  • EXCEPTION
  • external
  • EXCEPTION
  • federatedfilesharing
  • EXCEPTION
  • federation
  • EXCEPTION
  • files
  • EXCEPTION
  • files_antivirus
  • EXCEPTION
  • files_external
  • EXCEPTION
  • files_pdfviewer
  • EXCEPTION
  • files_sharing
  • EXCEPTION
  • files_texteditor
  • EXCEPTION
  • files_trashbin
  • EXCEPTION
  • files_versions
  • EXCEPTION
  • files_videoplayer
  • EXCEPTION
  • firstrunwizard
  • EXCEPTION
  • gallery
  • EXCEPTION
  • notifications
  • EXCEPTION
  • provisioning_api
  • EXCEPTION
  • systemtags
  • EXCEPTION
  • templateeditor
  • EXCEPTION
  • user_external
  • EXCEPTION
  • user_ldap
  • EXCEPTION
Raw output
Array
[core] => Array
[EXCEPTION] => Array
[class] => OC\IntegrityCheck\Exceptions\InvalidSignatureException
[message] => Signature could not get verified.
[activity] => Array
[comments] => Array
[dav] => Array
[encryption] => Array
[external] => Array
[federatedfilesharing] => Array
[federation] => Array
[files] => Array
[files_antivirus] => Array
[files_external] => Array
[files_pdfviewer] => Array
[files_sharing] => Array
[files_texteditor] => Array
[files_trashbin] => Array
[files_versions] => Array
[files_videoplayer] => Array
[firstrunwizard] => Array
[gallery] => Array
[notifications] => Array
[provisioning_api] => Array
[systemtags] => Array
[templateeditor] => Array
[user_external] => Array
[user_ldap] => Array
Thanks in advance for your help
Cordially,
PS : I don’t know if i place this post in the right place
How did you install owncloud? And how did you get the code on the machine?
Check also your logfiles for errors, perhaps some modules are missing or some resources are blocked.
Hi tflidd,
I made the install of owncloud by an repository.
i copy it here :
[ce_9.1]
name=ownCloud Server Version 9.1 (CentOS_7)
type=rpm-md
baseurl=download.owncloud.com
gpgcheck=1
gpgkey=download.owncloud.com
enabled=1
priority=7
I’m going to check logfiles, and reply you when have more information
Thx for your awnser
The repo should be fine, even the dependencies should be correctly solved. SELinux is perhaps not set up to work with owncloud.
SELinux is actually disable on this server , owncloud need it for work?
Problem solved , owncloud not work with php 7.1.1 , i had to uninstall php 7.1.1 for go as 5.6 , thx for your help
I investigate a definitive answer,
Find it here explained:
Regards,
Francois
