Code IntegrityCheck
I have disabled code integrity check by adding the following parameter in config.php ‘integrity.check.disabled’ => true, code integrity is successfully disabled.
Now i need to enable it again, but when i remove this line ‘integrity.check.disabled’ => true,
from config.php its not enabled. How can i re-enable it.
Please help
have you tried to restart your webserver?
