Collabora CODE: Ugly fonts with Windows browsers
I have successfully installed Collabora CODE and integrated with Owncloud 10. Everything works so far.
However, while editing documents with a Windows based browser the fonts are looking very ugly. If I do the same with a Mac OS based browser then it looks very pretty.
Has anyone also that issue and may also a solution for that?
Thanks a lot in advance.
P.S. If this is the not the right forum to ask for, then it would be great if someone can point me to a better place. Thanks.
So in Edge the fonts looks worse than in Safari?
Have you tried other browsers?
No, all browsers on Windows look not pretty. All browsers on my MacBook are ok. I think I improved the situation a bit now by replacing the file “/opt/collaboraoffice5.3/share/fonts/truetype/fc_local.conf” with another one (unfortunately I cannot upload a file here :-()
Okay, thanks for noticing.
One more question: What windows are you using?
Here is the right place to ask your question I suppose.
I have already created a topic for you, to save you some trouble.
Thank you! I am using Windows 7.
