- Install Owncloud 10 and Collabora
- Install Collabora server with this guide on Apache (Integrate Collabora Online with Nextcloud on Ubuntu without Docker)
3.Connect to collabora with http as server type (does not work with https)
Open and edit files.
- Collabora app shows files in the structure, but when you attempt to open one, you get the message “The content is blocked. Contact the site owner to fix the issue.”
- When you click on a ‘new’ file icon, The error message “Failed to open undefined, file not supported”
Ubuntu 20.04.02
Apache
fresh
repo
"basic": {
"license key": "***REMOVED SENSITIVE VALUE***",
"date": "Mon, 16 Aug 2021 22:23:55 +0000",
"ownCloud version": "10.8.0.4",
"ownCloud version string": "10.8.0",
"ownCloud edition": "Community",
"server OS": "Linux",
"server OS version": "Linux social 5.4.0-81-generic #91-Ubuntu SMP Thu Jul 15 19:09:17 UTC 2021 x86_64",
"server SAPI": "apache2handler",
"webserver version": "Apache\/2.4.41 (Ubuntu)",
"hostname": "*****",
"logged-in user": "****"
"stats": {
"users": {
"Database": {
"count": 3,
"seen": 3,
"logged in (30 days)": 3
"groups": {
"OC\\Group\\Database": 4,
"OCA\\Guests\\GroupBackend": 1
"config": {
"trusted_domains": [
"localhost",
"datadirectory": "\/mnt\/volume_nyc3_01\/owncloud_data\/",
"overwrite.cli.url": "http:\/\/localhost",
"overwriteprotocol": "https",
"dbtype": "mysql",
"version": "10.8.0.4",
"dbname": "owncloud",
"dbhost": "localhost",
"dbtableprefix": "oc_",
"mysql.utf8mb4": true,
"logtimezone": "UTC",
"apps_paths": [
"url": "\/apps",
"writable": false
"url": "\/apps-external",
"writable": true
"installed": true,
"instanceid": "ocw8p2rpbjqh",
"redis": {
"host": "127.0.0.1",
"port": "6379"
"maintenance": false,
"mail_smtpmode": "php"
"integritychecker": {
"passing": true,
"enabled": true,
"result": []
"core": {
"backgroundjobs_mode": "cron",
"first_install_version": "10.8.0.4",
"installedat": "1629000385.3928",
"lastcron": "1629152265",
"lastupdateResult": "[]",
"lastupdatedat": "1629151116",
"public_files": "files_sharing\/public.php",
"public_webdav": "dav\/appinfo\/v1\/publicwebdav.php",
"umgmt_show_storage_location": "false"
Enabled:
- comments:
- Version: 0.3.0
- configreport:
- Version: 0.2.0
- customgroups:
- Version: 0.6.2
- Path: /var/www/owncloud/apps-external/customgroups
- dav:
- Version: 0.6.0
- federatedfilesharing:
- Version: 0.5.0
- federation:
- Version: 0.1.0
- files:
- Version: 1.5.2
- files_antivirus:
- Version: 1.0.0
- Path: /var/www/owncloud/apps-external/files_antivirus
- files_external:
- Version: 0.8.0
- files_mediaviewer:
- Version: 1.0.4
- files_pdfviewer:
- Version: 0.12.2
- Path: /var/www/owncloud/apps-external/files_pdfviewer
- files_sharing:
- Version: 0.14.0
- files_texteditor:
- Version: 2.3.1
- Path: /var/www/owncloud/apps-external/files_texteditor
- files_trashbin:
- Version: 0.9.1
- files_versions:
- Version: 1.3.0
- firstrunwizard:
- Version: 1.2.0
- guests:
- Version: 0.9.2
- Path: /var/www/owncloud/apps-external/guests
- market:
- Version: 0.6.1
- notifications:
- Version: 0.5.4
- provisioning_api:
- Version: 0.5.0
- richdocuments:
- Version: 2.6.0
- Path: /var/www/owncloud/apps-external/richdocuments
- systemtags:
- Version: 0.3.0
- tasks:
- Version: 0.9.7
- Path: /var/www/owncloud/apps-external/tasks
- updatenotification:
- Version: 0.2.1
Disabled:
- encryption:
- external:
- user_external:
Are you using encryption: no
Brave
Ubuntu (desktop)
Web server access log (No errors pertaining to owncloud)
***clientIP*** - - [17/Aug/2021:02:17:45 +0000] "GET /index.php/apps/richdocuments/index HTTP/1.1" 200 3828 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/92.0.4515.131 Safari/537.36"
***clientIP*** - - [17/Aug/2021:02:17:45 +0000] "GET /index.php/core/js/oc.js?v=cddf5d11c0a3f75d41dad1d3892427f0 HTTP/1.1" 200 6254 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/92.0.4515.131 Safari/537.36"
***clientIP*** - - [17/Aug/2021:02:17:45 +0000] "GET /apps-external/richdocuments/img/app.svg HTTP/1.1" 304 202 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/92.0.4515.131 Safari/537.36"
***clientIP*** - - [17/Aug/2021:02:17:45 +0000] "GET /apps-external/tasks/img/tasks.svg HTTP/1.1" 304 782 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/92.0.4515.131 Safari/537.36"
***clientIP*** - - [17/Aug/2021:02:17:45 +0000] "GET /core/img/favicon.ico HTTP/1.1" 200 15724 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/92.0.4515.131 Safari/537.36"
***clientIP*** - - [17/Aug/2021:02:17:45 +0000] "GET /ocs/v2.php/apps/notifications/api/v1/notifications?format=json HTTP/1.1" 200 936 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/92.0.4515.131 Safari/537.36"
***clientIP*** - - [17/Aug/2021:02:17:45 +0000] "GET /index.php/apps/richdocuments/ajax/documents/list HTTP/1.1" 200 7554 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/92.0.4515.131 Safari/537.36"
***clientIP*** - - [17/Aug/2021:02:17:47 +0000] "GET /index.php/apps/richdocuments/index?fileId=60 HTTP/1.1" 200 3941 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/92.0.4515.131 Safari/537.36"
***clientIP*** - - [17/Aug/2021:02:17:47 +0000] "GET /index.php/core/js/oc.js?v=cddf5d11c0a3f75d41dad1d3892427f0 HTTP/1.1" 200 6254 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/92.0.4515.131 Safari/537.36"
***clientIP*** - - [17/Aug/2021:02:17:47 +0000] "GET /ocs/v2.php/apps/notifications/api/v1/notifications?format=json HTTP/1.1" 200 936 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/92.0.4515.131 Safari/537.36"
{"reqId":"P7EWbwEI3ERPl4t5AdKQ","level":3,"time":"2021-08-16T22:20:46+00:00","remoteAddr":"***clientIP***","user":"**user**","app":"PHP","method":"GET","url":"\/index.php\/apps\/richdocuments\/index","message":"Undefined index: version at \/var\/www\/owncloud\/apps-external\/richdocuments\/templates\/documents.php#3"}
{"reqId":"P7EWbwEI3ERPl4t5AdKQ","level":3,"time":"2021-08-16T22:20:46+00:00","remoteAddr":"***clientIP***","user":"**user**","app":"PHP","method":"GET","url":"\/index.php\/apps\/richdocuments\/index","message":"Undefined index: sessionId at \/var\/www\/owncloud\/apps-external\/richdocuments\/templates\/documents.php#4"}
{"reqId":"P7EWbwEI3ERPl4t5AdKQ","level":3,"time":"2021-08-16T22:20:46+00:00","remoteAddr":"***clientIP***","user":"**user**","app":"PHP","method":"GET","url":"\/index.php\/apps\/richdocuments\/index","message":"Undefined index: permissions at \/var\/www\/owncloud\/apps-external\/richdocuments\/templates\/documents.php#5"}
{"reqId":"P7EWbwEI3ERPl4t5AdKQ","level":3,"time":"2021-08-16T22:20:46+00:00","remoteAddr":"***clientIP***","user":"**user**","app":"PHP","method":"GET","url":"\/index.php\/apps\/richdocuments\/index","message":"Undefined index: title at \/var\/www\/owncloud\/apps-external\/richdocuments\/templates\/documents.php#6"}
{"reqId":"P7EWbwEI3ERPl4t5AdKQ","level":3,"time":"2021-08-16T22:20:46+00:00","remoteAddr":"***clientIP***","user":"**user**","app":"PHP","method":"GET","url":"\/index.php\/apps\/richdocuments\/index","message":"Undefined index: fileId at \/var\/www\/owncloud\/apps-external\/richdocuments\/templates\/documents.php#7"}
{"reqId":"P7EWbwEI3ERPl4t5AdKQ","level":3,"time":"2021-08-16T22:20:46+00:00","remoteAddr":"***clientIP***","user":"**user**","app":"PHP","method":"GET","url":"\/index.php\/apps\/richdocuments\/index","message":"Undefined index: access_token at \/var\/www\/owncloud\/apps-external\/richdocuments\/templates\/documents.php#8"}
{"reqId":"P7EWbwEI3ERPl4t5AdKQ","level":3,"time":"2021-08-16T22:20:46+00:00","remoteAddr":"***clientIP***","user":"**user**","app":"PHP","method":"GET","url":"\/index.php\/apps\/richdocuments\/index","message":"Undefined index: access_token_ttl at \/var\/www\/owncloud\/apps-external\/richdocuments\/templates\/documents.php#9"}
{"reqId":"P7EWbwEI3ERPl4t5AdKQ","level":3,"time":"2021-08-16T22:20:46+00:00","remoteAddr":"***clientIP***","user":"**user**","app":"PHP","method":"GET","url":"\/index.php\/apps\/richdocuments\/index","message":"Undefined index: urlsrc at \/var\/www\/owncloud\/apps-external\/richdocuments\/templates\/documents.php#10"}
{"reqId":"P7EWbwEI3ERPl4t5AdKQ","level":3,"time":"2021-08-16T22:20:46+00:00","remoteAddr":"***clientIP***","user":"**user**","app":"PHP","method":"GET","url":"\/index.php\/apps\/richdocuments\/index","message":"Undefined index: path at \/var\/www\/owncloud\/apps-external\/richdocuments\/templates\/documents.php#11"}
{"reqId":"P7EWbwEI3ERPl4t5AdKQ","level":3,"time":"2021-08-16T22:20:46+00:00","remoteAddr":"***clientIP***","user":"**user**","app":"PHP","method":"GET","url":"\/index.php\/apps\/richdocuments\/index","message":"Undefined index: uploadMaxHumanFilesize at \/var\/www\/owncloud\/apps-external\/richdocuments\/templates\/documents.php#50"}
{"reqId":"P7EWbwEI3ERPl4t5AdKQ","level":3,"time":"2021-08-16T22:20:46+00:00","remoteAddr":"***clientIP***","user":"**user**","app":"PHP","method":"GET","url":"\/index.php\/apps\/richdocuments\/index","message":"Undefined index: uploadMaxFilesize at \/var\/www\/owncloud\/apps-external\/richdocuments\/templates\/documents.php#58"}
{"reqId":"P7EWbwEI3ERPl4t5AdKQ","level":3,"time":"2021-08-16T22:20:46+00:00","remoteAddr":"***clientIP***","user":"**user**","app":"PHP","method":"GET","url":"\/index.php\/apps\/richdocuments\/index","message":"Undefined index: uploadMaxFilesize at \/var\/www\/owncloud\/apps-external\/richdocuments\/templates\/documents.php#60"}
{"reqId":"P7EWbwEI3ERPl4t5AdKQ","level":3,"time":"2021-08-16T22:20:46+00:00","remoteAddr":"***clientIP***","user":"**user**","app":"PHP","method":"GET","url":"\/index.php\/apps\/richdocuments\/index","message":"Undefined index: uploadMaxHumanFilesize at \/var\/www\/owncloud\/apps-external\/richdocuments\/templates\/documents.php#66"}
