Thanks for reporting issues back to ownCloud! This is the issue tracker of ownCloud, if you have any support question please check out https://owncloud.org/support
This is the bug tracker for the Server component. Find other components at https://github.com/owncloud/core/blob/master/.github/CONTRIBUTING.md#guidelines
For reporting potential security issues please see https://owncloud.org/security/
To make it possible for us to help you please fill out below information carefully.
Before reporting any issues please make sure that you’re using the latest available version for your major branch (e.g. 9.0.x), see https://owncloud.org/changelog/
- Desktop client not syncing
- It does not allow to share a public link from the web
Synchronize without problem with the client and be able to share public links from the web
An exception occurred while executing ‘INSERT INTO oc_share
(share_type
, token
, parent
, share_name
, item_type
, item_source
, file_source
, permissions
, attributes
, uid_initiator
, uid_owner
, file_target
, stime
) VALUES(?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)’ with params [3, “ZMe25TACLGQ5RtP”, null, “Enlace Publico”, “file”, 156295, 156295, 1, null, “soporte”, “soporte”, “/prueba.txt”, 1638836917]: SQLSTATE[42S22]: Column not found: 1054 Unknown column ‘attributes’ in ‘field list’
ubuntu 20.04.3
owncloud
10.8.0.4
No errors have been found
?php
$CONFIG = array (
'instanceid' => '%%%%',
'passwordsalt' => '%%%%',
'secret' => '%%%',
'trusted_domains' =>
array (
0 => '%%%%%',
1 => '%%%%%%',
2 => '%%%%%%',
'datadirectory' => '/var/www/owncloud/data',
'overwrite.cli.url' => 'https://prueba.ddns.net',
'dbtype' => 'mysql',
'version' => '10.8.0.4',
'dbname' => 'owncloud',
'dbhost' => 'localhost',
'dbtableprefix' => 'oc_',
'mysql.utf8mb4' => true,
'dbuser' => 'owncloud',
'dbpassword' => '%%%%%%%',
'logtimezone' => 'UTC',
'apps_paths' =>
array (
0 =>
array (
'url' => '/apps',
'writable' => false,
1 =>
array (
'path' => '/var/www/owncloud/apps-external',
'url' => '/apps-external',
'writable' => true,
'installed' => true,
'loglevel' => 3,
'maintenance' => false,
'redis' =>
array (
'host' => 'localhost',
'port' => 6379,
'timeout' => 0.0,
**List of activated apps:**
With access to your command line run e.g
