Command “upgrade” is not defined
I want to update Owncloud on my Synology.
I used this guide and got the following error when upgrading.
http://www.iholken.com/index.php/2016/07/24/upgrade-owncloud-9-x-to-9-1-in-synology-nas-running-dsm6
sh-4.3# sudo -u http php56 occ upgrade
ownCloud is not installed – only a limited number of commands are available
[Symfony\Component\Console\Exception\CommandNotFoundException]
Command “upgrade” is not defined.
Any hints on this ?
Sascha
Solved it.
I had to restart the Apache and not the Webservice.
