Hallo !
I am new on owncloud.
installation was successfully and I have installed the caldav add-on.
Now I am searching for a php script, which allows me:
- conntect to caldav server
- create / delete / modify / get events
Is there a solution available?
Hallo !
There is no such thing like a caldav add-on. Do you mean the calendar app?
BTW, owncloud server IS the CalDAV-Server. Of course it’s possible to edit the calendars with a PHP script, but I strongly doubt that this is what you want. Or I completely misunderstood your post.
Maybe you should try to give more detailed information.
yes, I mean the calendar app, sorry
I know, that owncloud IS the caldav server
I would like to add / modify / delete events with a php script.
And start a query to get events
