Connect to OwnCloud FTP
Is it possible to connect to our shared files in ownclod through FTP?
No. You have to use a WebDAV aware client.
Okay, so WinSCP exampel? hostname is the url and using username and password?
I don’t know WinSCP, sorry.
What would you reccomend?
I’m not using windows, but as you might have WinSCP, I think you can use if for communicating with ownCloud, I seems to support WebDAV.
WinSCP is a popular free SFTP and FTP client for Windows, a powerful file manager that will improve your productivity. It supports also Amazon S3, FTPS, SCP and WebDAV protocols.
does not seem to work.
I go to cloud.domain.com and uses username and password.
I get error message 405 Method Not Allowed error listing directory ‘/’
The URL has to be like
https://cloud.domain.com/remote.php/dav/files/username/
how to access the files within ownCloud with WebDAV seems to be also thoroughly described in the documentation provided by the ownCloud people here:
https://doc.owncloud.org/server/10.5/user_manual/files/access_webdav.html
@happywillz Could you bring it to work? Would be helpful to know.
