I have a problem with External Windows Storage connection to OwnCloud. May be this topic is familiar with another, but I didn't find the answer yet. I have downloaded OwnCloud Enterprise virtual appliance from website. Started it and can't understand how to connect windows share to OwnCloud. I can't even find share from my OwnCloud web site. SMB package is installed. How it should be done?
Hi, Thank you I looked through this doc. But I can't find settings described in this article in my OwnCloud Do I need to install Windows App like in this document? Even if I downloaded appliance from OwnCloud site? And how can I get Windows App? Looks like I need to buy it?
How can I check this? I see smb package in package list. But I can't see windows app in application list. And in list of applications which could be installed too
There are 2 "app stores" the one in your screen shot is the univention app store.
Windows network drive app should be already installed, if not you have to log in to owncloud, and go to the upper left corner and click on market, there you should find the WND app.
Okay, you don't have the ownCloud app installed. You would have to click on system and domain settings, log in to the UMC, go to the appstore of univetion, and install the owncloud app.
