Connecting OneDrive through WebDav
  1. Create external storage WebDav
  2. Url Http://d.docs.live.net/ + personal CID
  3. Username and Password authentication
Should create and access onedrive as external storage
shows a folder for the WebDav but when clicked geting error
ownCloud
Service Unavailable
Technical details
  • Remote Address: 93.105.177.90
  • Request ID: XB1ZnmQeG3JewhIKvT5gqAAAAIE
Request ID changes everytime I try to access the folder.
I am using infomaniak provider
10.0.10
I cannot upload the log file because I am a new user
OneDrive’s WebDAV implementation does not use standard protocols and is only usable as a Windows Network Location. You are also limited to only uploading files under 100 MB (same limits that apply if you drag-and-drop files onto OneDrive’s web UI).
