I have an owncloud server running in a hosted enviroment which perfectly fine. We have a sister company which also runs owncloud, and now we need to share some files.
The idea was to use federated sharing, however we are experiencing some issues.
I can add their server in the trusted server list, however they cannot add mine.
When they try they get this error: Client error response [url] 212.98.105.132/status.php [status code] 404 [reason phrase] Not Found
I have pasted some info about my system below, but dont have too much info about their system unfortunately.
Other server should be able to add our server.
We are getting the error: Client error response [url] 212.98.105.132/status.php [status code] 404 [reason phrase] Not Found
Operating system: Ubuntu 16.04.3 LTS
Web server: apache 2
**Database:**MySQL
PHP version: PHP 7.0.22-0ubuntu0.16.04.1
ownCloud version:: 9.1.6
**Updated from an older ownCloud or fresh install: fresh install
**Where did you install ownCloud from: The official package
**The content of config/config.php:
$CONFIG = array (
‘updatechecker’ => false,
‘instanceid’ => ‘ocz8ky2fap1w’,
‘passwordsalt’ => ‘JTHQPaEqH29n1mu5+XOG3JxbOHoF8i’,
‘secret’ => ‘wMo43JWcyP8N7rD+Vy1WVBjEFUvMEE/xD8zXivEvlt0c22dC’,
‘trusted_domains’ =>
array (
0 => ‘ip of server’,
1 => ‘0.0.0.0’,
2 => ‘10.8.0.0’,
‘datadirectory’ => ‘/var/www/owncloud/data’,
‘overwrite.cli.url’ => ‘insert ip here/owncloud’,
‘dbtype’ => ‘mysql’,
‘version’ => ‘9.1.6.2’,
‘dbname’ => ‘owncloud’,
‘dbhost’ => ‘localhost’,
‘dbtableprefix’ => ‘oc_’,
‘dbuser’ => ‘oc_admin’,
‘dbpassword’ => ‘M6Smmf75ibU8zmOBjvNYxC3aI+E06L’,
‘logtimezone’ => ‘UTC’,
‘installed’ => true,
‘mail_from_address’ => ‘das’,
‘mail_smtpmode’ => ‘php’,
‘mail_domain’ => ‘fake domain’,
‘maintenance’ => false,
‘theme’ => ‘’,
‘loglevel’ => 2,
(just the last couple of lines):
{"reqId":"LIyug5phYDJI0MaWZlfT","remoteAddr":"185.96.91.2","app":"federation","message":"cURL error 28: Resolving timed out after 3513 milliseconds","level":3,"time":"2018-04-12T07:06:18+00:00","method":"POST","url":"\/owncloud\/index.php\/apps\/federation\/trusted-servers","user":"admin"}
{"reqId":"WN7EwdK9xg0iFlkRX5ld","remoteAddr":"185.96.91.2","app":"core","message":"Login failed: 'Lars' (Remote IP: '185.96.91.2')","level":2,"time":"2018-04-12T14:01:04+00:00","method":"PROPFIND","url":"\/owncloud\/remote.php\/webdav\/","user":"--"}
{"reqId":"hnK7O8MQRcAaIlNd98qM","remoteAddr":"185.96.91.2","app":"core","message":"Login failed: 'Lars' (Remote IP: '185.96.91.2')","level":2,"time":"2018-04-12T14:01:09+00:00","method":"PROPFIND","url":"\/owncloud\/remote.php\/webdav\/","user":"--"}
{"reqId":"ZsWqzafcDI\/LCQ1OENpL","remoteAddr":"185.96.91.2","app":"core","message":"Login failed: 'Lars' (Remote IP: '185.96.91.2')","level":2,"time":"2018-04-12T14:01:15+00:00","method":"PROPFIND","url":"\/owncloud\/remote.php\/webdav\/","user":"--"}
{"reqId":"8z9lORMs7XE14Qt0s2ty","remoteAddr":"185.96.91.2","app":"federation","message":"cURL error 28: Resolving timed out after 3514 milliseconds","level":3,"time":"2018-04-17T10:04:48+00:00","method":"POST","url":"\/owncloud\/index.php\/apps\/federation\/trusted-servers","user":"admin"}
{"reqId":"VkEytR9q2FlPkWS2kYom","remoteAddr":"185.96.91.2","app":"federation","message":"cURL error 28: Connection timed out after 3001 milliseconds","level":3,"time":"2018-04-17T10:30:05+00:00","method":"POST","url":"\/owncloud\/index.php\/apps\/federation\/trusted-servers","user":"admin"}
{"reqId":"LiQ6HfxyJOxt9mnZ\/Fsn","remoteAddr":"172.16.65.206","app":"core","message":"Trusted domain error. \"172.16.65.206\" tried to access using \"172.16.65.205\" as host.","level":2,"time":"2018-04-24T07:54:46+00:00","method":"GET","url":"\/owncloud\/status.php","user":"--"}
{"reqId":"pyLr4v2B+qN+k8x2ohSI","remoteAddr":"172.16.65.206","app":"core","message":"Trusted domain error. \"172.16.65.206\" tried to access using \"172.16.65.205\" as host.","level":2,"time":"2018-04-24T07:54:47+00:00","method":"GET","url":"\/owncloud\/status.php","user":"--"}
{"reqId":"Ho7leC8GUHMUaoNFTDSk","remoteAddr":"172.16.65.206","app":"core","message":"Trusted domain error. \"172.16.65.206\" tried to access using \"172.16.65.205\" as host.","level":2,"time":"2018-04-24T07:55:06+00:00","method":"GET","url":"\/owncloud\/status.php","user":"--"}
{"reqId":"8Xal3KEy9shPXjorpS8d","remoteAddr":"172.16.65.206","app":"core","message":"Trusted domain error. \"172.16.65.206\" tried to access using \"172.16.65.205\" as host.","level":2,"time":"2018-04-24T07:55:07+00:00","method":"GET","url":"\/owncloud\/status.php","user":"--"}
{"reqId":"yCU3rc\/19L\/HkjWqWYD5","remoteAddr":"172.16.65.206","app":"core","message":"Trusted domain error. \"172.16.65.206\" tried to access using \"172.16.65.205\" as host.","level":2,"time":"2018-04-24T07:56:34+00:00","method":"GET","url":"\/owncloud\/status.php","user":"--"}
{"reqId":"oAdWkMCx0507\/Z7h\/r1D","remoteAddr":"172.16.65.206","app":"core","message":"Trusted domain error. \"172.16.65.206\" tried to access using \"172.16.65.205\" as host.","level":2,"time":"2018-04-24T07:56:34+00:00","method":"GET","url":"\/owncloud\/status.php","user":"--"}
{"reqId":"sW0SFOY\/Hu9Fv\/vnnM1b","remoteAddr":"172.16.65.206","app":"core","message":"Trusted domain error. \"172.16.65.206\" tried to access using \"172.16.65.205\" as host.","level":2,"time":"2018-04-24T07:56:41+00:00","method":"GET","url":"\/owncloud\/status.php","user":"--"}
{"reqId":"YTZQQMTdYCBPgR0xbDlH","remoteAddr":"172.16.65.206","app":"core","message":"Trusted domain error. \"172.16.65.206\" tried to access using \"172.16.65.205\" as host.","level":2,"time":"2018-04-24T07:56:41+00:00","method":"GET","url":"\/owncloud\/status.php","user":"--"}
{"reqId":"rGjGHHZHxXIFiUdaogjJ","remoteAddr":"172.16.65.206","app":"core","message":"Trusted domain error. \"172.16.65.206\" tried to access using \"172.16.65.205\" as host.","level":2,"time":"2018-04-24T07:58:34+00:00","method":"GET","url":"\/owncloud\/","user":"--"}
{"reqId":"XtYGoGPRA086\/wJ+7CvN","remoteAddr":"172.16.65.206","app":"core","message":"Trusted domain error. \"172.16.65.206\" tried to access using \"172.16.65.205\" as host.","level":2,"time":"2018-04-24T07:58:34+00:00","method":"GET","url":"\/owncloud\/index.php\/core\/js\/oc.js?v=3aabbe96c4399d877cea6ce49c0402f4","user":"--"}
{"reqId":"bVespL6JT4xOWSenhbIc","remoteAddr":"172.16.65.206","app":"core","message":"Trusted domain error. \"172.16.65.206\" tried to access using \"172.16.65.205\" as host.","level":2,"time":"2018-04-24T07:58:35+00:00","method":"GET","url":"\/owncloud\/cron.php","user":"--"}
{"reqId":"62VELe4XZqfTgYFVffxr","remoteAddr":"172.16.65.206","app":"core","message":"Trusted domain error. \"172.16.65.206\" tried to access using \"172.16.65.205\" as host.","level":2,"time":"2018-04-24T07:58:46+00:00","method":"GET","url":"\/owncloud\/status.php","user":"--"}
{"reqId":"8t3mjhpm9QkoWrCMNXOy","remoteAddr":"172.16.65.206","app":"core","message":"Trusted domain error. \"172.16.65.206\" tried to access using \"172.16.65.205\" as host.","level":2,"time":"2018-04-24T07:58:46+00:00","method":"GET","url":"\/owncloud\/","user":"--"}
{"reqId":"BJlfqV2KfMTllgsAPnlS","remoteAddr":"172.16.65.206","app":"core","message":"Trusted domain error. \"172.16.65.206\" tried to access using \"172.16.65.205\" as host.","level":2,"time":"2018-04-24T07:58:47+00:00","method":"GET","url":"\/owncloud\/status.php","user":"--"}
{"reqId":"HpnIoBlmAlWJuhdYffyy","remoteAddr":"172.16.65.206","app":"core","message":"Trusted domain error. \"172.16.65.206\" tried to access using \"172.16.65.205\" as host.","level":2,"time":"2018-04-24T07:59:02+00:00","method":"GET","url":"\/owncloud\/status.php","user":"--"}
{"reqId":"DqUj2XiuRLPPikYYPxAh","remoteAddr":"172.16.65.206","app":"core","message":"Trusted domain error. \"172.16.65.206\" tried to access using \"172.16.65.205\" as host.","level":2,"time":"2018-04-24T07:59:02+00:00","method":"GET","url":"\/owncloud\/","user":"--"}
{"reqId":"kN49EZa4PC+QNUQPw2rV","remoteAddr":"172.16.65.206","app":"core","message":"Trusted domain error. \"172.16.65.206\" tried to access using \"172.16.65.205\" as host.","level":2,"time":"2018-04-24T07:59:03+00:00","method":"GET","url":"\/owncloud\/status.php","user":"--"}
{"reqId":"+6GKukc0PhIGObI++eyU","remoteAddr":"172.16.65.206","app":"core","message":"Trusted domain error. \"172.16.65.206\" tried to access using \"172.16.65.205\" as host.","level":2,"time":"2018-04-24T08:00:31+00:00","method":"GET","url":"\/owncloud\/","user":"--"}
{"reqId":"Hk\/E9zLCbfsAwUG3cLLA","remoteAddr":"172.16.65.206","app":"core","message":"Trusted domain error. \"172.16.65.206\" tried to access using \"172.16.65.205\" as host.","level":2,"time":"2018-04-24T08:00:31+00:00","method":"GET","url":"\/owncloud\/index.php\/core\/js\/oc.js?v=3aabbe96c4399d877cea6ce49c0402f4","user":"--"}
{"reqId":"n0zUCxgr08+4ZJKmDi5U","remoteAddr":"172.16.65.206","app":"core","message":"Trusted domain error. \"172.16.65.206\" tried to access using \"172.16.65.205\" as host.","level":2,"time":"2018-04-24T08:00:32+00:00","method":"GET","url":"\/owncloud\/cron.php","user":"--"}
{"reqId":"fcyb3k+Pr+jrj99Kfiz2","remoteAddr":"172.16.65.206","app":"core","message":"Trusted domain error. \"172.16.65.206\" tried to access using \"172.16.65.205\" as host.","level":2,"time":"2018-05-04T08:54:34+00:00","method":"GET","url":"\/owncloud\/status.php","user":"--"}
{"reqId":"JoM6r1IDAzM95NSmnyXa","remoteAddr":"172.16.65.206","app":"core","message":"Trusted domain error. \"172.16.65.206\" tried to access using \"172.16.65.205\" as host.","level":2,"time":"2018-05-04T08:54:34+00:00","method":"GET","url":"\/owncloud\/","user":"--"}
{"reqId":"oivM4eclAAXhPugQ5JCM","remoteAddr":"172.16.65.206","app":"core","message":"Trusted domain error. \"172.16.65.206\" tried to access using \"172.16.65.205\" as host.","level":2,"time":"2018-05-04T08:54:34+00:00","method":"GET","url":"\/owncloud\/status.php","user":"--"}
{"reqId":"L51AZD\/TETQs3y4tCZsm","remoteAddr":"172.16.65.206","app":"core","message":"Trusted domain error. \"172.16.65.206\" tried to access using \"172.16.65.205\" as host.","level":2,"time":"2018-05-04T08:56:42+00:00","method":"GET","url":"\/owncloud\/status.php","user":"--"}
{"reqId":"aVvIXnZwv19ypvpr5ELY","remoteAddr":"172.16.65.206","app":"core","message":"Trusted domain error. \"172.16.65.206\" tried to access using \"172.16.65.205\" as host.","level":2,"time":"2018-05-04T08:56:42+00:00","method":"GET","url":"\/owncloud\/","user":"--"}
{"reqId":"t3UQFylozD7ESW9\/APWh","remoteAddr":"172.16.65.206","app":"core","message":"Trusted domain error. \"172.16.65.206\" tried to access using \"172.16.65.205\" as host.","level":2,"time":"2018-05-04T08:56:42+00:00","method":"GET","url":"\/owncloud\/status.php","user":"--"}
{"reqId":"axuJnQ9CM6glz4mZZVUo","remoteAddr":"172.16.65.206","app":"core","message":"Trusted domain error. \"172.16.65.206\" tried to access using \"172.16.65.205\" as host.","level":2,"time":"2018-05-04T09:43:02+00:00","method":"GET","url":"\/owncloud\/status.php","user":"--"}
{"reqId":"yiz4AExqh3MW2BQKWyIj","remoteAddr":"172.16.65.206","app":"core","message":"Trusted domain error. \"172.16.65.206\" tried to access using \"172.16.65.205\" as host.","level":2,"time":"2018-05-04T09:43:02+00:00","method":"GET","url":"\/owncloud\/","user":"--"}
{"reqId":"qVgANXMkb96nq0YP279C","remoteAddr":"172.16.65.206","app":"core","message":"Trusted domain error. \"172.16.65.206\" tried to access using \"172.16.65.205\" as host.","level":2,"time":"2018-05-04T09:43:02+00:00","method":"GET","url":"\/owncloud\/status.php","user":"--"}
{"reqId":"Sv2+b+Y5\/MWJgFwoTVNS","remoteAddr":"172.16.65.206","app":"core","message":"Trusted domain error. \"172.16.65.206\" tried to access using \"172.16.65.205\" as host.","level":2,"time":"2018-05-04T09:43:25+00:00","method":"GET","url":"\/owncloud\/status.php","user":"--"}
{"reqId":"bZsPVBmVPS3NmPjOQP9T","remoteAddr":"172.16.65.206","app":"core","message":"Trusted domain error. \"172.16.65.206\" tried to access using \"172.16.65.205\" as host.","level":2,"time":"2018-05-04T09:43:25+00:00","method":"GET","url":"\/owncloud\/","user":"--"}
{"reqId":"4yUuuYU4z92KZR4nl7hu","remoteAddr":"172.16.65.206","app":"core","message":"Trusted domain error. \"172.16.65.206\" tried to access using \"172.16.65.205\" as host.","level":2,"time":"2018-05-04T09:43:25+00:00","method":"GET","url":"\/owncloud\/status.php","user":"--"}
{"reqId":"eHw0A9aAQjqah025V3HO","remoteAddr":"172.16.65.206","app":"core","message":"Trusted domain error. \"172.16.65.206\" tried to access using \"172.16.65.205:80\" as host.","level":2,"time":"2018-05-07T07:05:08+00:00","method":"GET","url":"\/owncloud\/status.php","user":"--"}
{"reqId":"S6wkRecSg5B\/h8C\/Dai8","remoteAddr":"172.16.65.206","app":"core","message":"Trusted domain error. \"172.16.65.206\" tried to access using \"172.16.65.205:80\" as host.","level":2,"time":"2018-05-07T07:05:08+00:00","method":"GET","url":"\/owncloud\/status.php","user":"--"}
{"reqId":"PtVq+5Tn7p3liAv24SYQ","remoteAddr":"172.16.65.206","app":"core","message":"Trusted domain error. \"172.16.65.206\" tried to access using \"172.16.65.205\" as host.","level":2,"time":"2018-05-07T09:33:00+00:00","method":"GET","url":"\/owncloud\/status.php","user":"--"}
{"reqId":"yTJuYE6vHqknBdoCBzwr","remoteAddr":"172.16.65.206","app":"core","message":"Trusted domain error. \"172.16.65.206\" tried to access using \"172.16.65.205\" as host.","level":2,"time":"2018-05-07T09:33:00+00:00","method":"GET","url":"\/owncloud\/status.php","user":"--"}
{"reqId":"lfzJz0sF8\/lEdRGa+0NR","remoteAddr":"172.16.65.206","app":"core","message":"Trusted domain error. \"172.16.65.206\" tried to access using \"172.16.65.205:80\" as host.","level":2,"time":"2018-05-07T09:33:15+00:00","method":"GET","url":"\/owncloud\/status.php","user":"--"}
{"reqId":"6lsu0Z96zJp5YZJcMgDM","remoteAddr":"172.16.65.206","app":"core","message":"Trusted domain error. \"172.16.65.206\" tried to access using \"172.16.65.205\" as host.","level":2,"time":"2018-05-07T09:33:15+00:00","method":"GET","url":"\/owncloud\/","user":"--"}
{"reqId":"fTmBWcedHOczpqJ0v9\/p","remoteAddr":"172.16.65.206","app":"core","message":"Trusted domain error. \"172.16.65.206\" tried to access using \"172.16.65.205\" as host.","level":2,"time":"2018-05-07T09:33:15+00:00","method":"GET","url":"\/owncloud\/status.php","user":"--"}
{"reqId":"rlDOtr4QmuLRN++LEwHx","remoteAddr":"185.96.91.2","app":"core","message":"Could not get categories: cURL error 7: Failed to connect to api.owncloud.com port 443: No route to host","level":3,"time":"2018-05-23T10:36:29+00:00","method":"GET","url":"\/owncloud\/index.php\/apps\/configreport\/report","user":"admin"}
