Constant re-sync problem / data usage explosion
Files that have not changed should not continuously sync.
Three days ago I received a notice that my data usage has exploded, and I determined that the culprit is the OC server running in my basement where 5+gigs of data is being re-sync’d continuously, over and over again, even though none of the files have changed. The server then sends the files back out to multiple clients, over and over.
Ubuntu 16.10
Apache2
mysql
10.0.0.12
updated
“basic”: {
“license key”: “”,
“date”: “Tue, 04 Jul 2017 01:15:55 +0000”,
“ownCloud version”: “10.0.0.12”,
“ownCloud version string”: “10.0.0”,
“ownCloud edition”: “Community”,
“server OS”: “Linux”,
“server OS version”: “Linux jet 4.8.0-58-generic #63-Ubuntu SMP Mon Jun 26 17:08:21 UTC 2017 x86_64”,
“server SAPI”: “apache2handler”,
“webserver version”: “Apache/2.4.18 (Ubuntu)”,
“hostname”: “XXXXXX”,
“user count”: 14,
“user directories”: 14,
“logged-in user”: “XXXXXX”
“config”: {
“updatechecker”: false,
“instanceid”: “oczsx0tbcodr”,
“trusted_domains”: [
“datadirectory”: “/media/4T/oc-data/”,
“overwrite.cli.url”: “http://localhost/owncloud”,
“dbtype”: “mysql”,
“version”: “10.0.0.12”,
“dbname”: “oc_2017”,
“dbhost”: “localhost”,
“dbtableprefix”: “oc_”,
“logtimezone”: “UTC”,
“installed”: true,
“maintenance”: false,
“theme”: “”,
“loglevel”: 2,
“trashbin_retention_obligation”: “auto”,
“0”: 10,
“versions_retention_obligation”: “auto”,
“1”: 5,
“allow_user_to_change_display_name”: true,
“updater.secret”: “REMOVED SENSITIVE VALUE
“integritychecker”: {
“passing”: true,
“enabled”: true,
“result”:
“core”: {
“installedat”: “1483661997.4416”,
“lastcron”: “1499130952”,
“lastupdateResult”: “{"version":"10.0.2","versionstring":"ownCloud 10.0.2","url":"https:\/\/download.owncloud.org\/community\/owncloud-10.0.2.zip","web":"https:\/\/doc.owncloud.org\/server\/10.0\/admin_manual\/maintenance\/upgrade.html"}”,
“lastupdatedat”: “1499130915”,
“public_files”: “files_sharing/public.php”,
“public_webdav”: “dav/appinfo/v1/publicwebdav.php”,
“shareapi_allow_public_upload”: “no”,
“shareapi_allow_resharing”: “no”,
“shareapi_allow_social_share”: “no”,
“shareapi_default_expire_date”: “yes”,
“shareapi_enabled”: “yes”,
“shareapi_expire_after_n_days”: “4”,
“updater.secret.created”: “1499004058”,
“vendor”: “”
we will need at least the ownCloud log to see what is happening here.
The log file is here: Dropbox - File Deleted - Simplify your life
thanks for your help!
Personally i would update to 10.0.2 first or even wait for 10.0.3 before trying to search an issue in a not recent / stable version.
